code 034 please help me
Old Apr 28, 2005 | 01:23 AM
  #51
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
As Ben Stiller said in Starsky and Hutch: Do it!
Old Apr 29, 2005 | 05:20 AM
  #52
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
sounds like a plan to me. also, whenever i say "do it" i say it like the cop from supertroopers hen those two guys were chuging syrup. "DOoooo iit"
Old May 6, 2005 | 01:38 PM
  #53
Xophertony's Avatar
Axle/Gears: n/a
well,m despite me not having a recipt for it, the guy at knechkts is going to replace my MAF. man those guys rule. it's on order i should have it in a week or two (he called like 5 distributers, all backordered)
Old May 6, 2005 | 02:25 PM
  #54
KED85's Avatar
Yeah this is the cheap fix swapping for new one if recent.
Let someone else fix that problem one
Hope ya get the right results.
Old May 6, 2005 | 02:27 PM
  #55
Xophertony's Avatar
Axle/Gears: n/a
me too, if it's not that sensor it is one of two things
1)i need to replace the whole wire, all the way to the ECM
2)i need to replace the ECM
Old May 6, 2005 | 04:19 PM
  #56
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ecms are easy to find in the boneyard.
if you grab enough odd things to make the guy at the counter overlook the ecm and forget how much they cost you can get them for cheap.
however walk up with just the ecm and he will charge you more
Old May 6, 2005 | 10:29 PM
  #57
Xophertony's Avatar
Axle/Gears: n/a
my local boneyard has LIMITED pickings. i went a few weeks ago, i had not been in six months. they had 7 3rd gens last time i went (last time i got a power bulge hood!) this time they had 5. of the five 1 was new.
Old May 7, 2005 | 02:26 AM
  #58
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
I duno if its been said, I really dont wanna read all of it BUT when I got a code 34, it was my altenator. Might wanna test that if anything else is bein wierd with the car. Just a thought
Old May 7, 2005 | 02:52 PM
  #59
Xophertony's Avatar
Axle/Gears: n/a
good thought, is that one of the things AZ does for free?
Old May 7, 2005 | 02:57 PM
  #60
KED85's Avatar
IF you have a lifetime warranty on it, just replace it!
It could be like mine was giving out intermitatant high voltage bursts shorting out stuff.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
