Timing Chain replacement?
Old Apr 14, 2005 | 11:01 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Am I reading this right??? The Haynes manual says to replace after 25,000 Miles?!?!?! Are they freakin kidding??
Old Apr 14, 2005 | 11:29 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
mine had to be stock, i'd say every 100000 miles, but a new one sure does pep the motor up
Old Apr 15, 2005 | 01:02 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
But that 25,000 mile interval is total BS...Who are they trying to screw?
Old Apr 15, 2005 | 03:12 PM
KED85's Avatar
That's not exactly wrong.
The copywriter may have picked up previous used type & just inserted. Someone else said OK next page to proofread.
But they tend to go for about 50,000-75,000.
And it is wise to check stretch during this period, too.
IF ya ever saw a stock GM item you'd be more amazed it lasted that long LOLOL!
You should see the specs on Alfa Romero.
REBUILD CYLINDER HEAD along with......at 40,000-60,000 miles.
Fiats!
IF they lasted long enough to go down the driveway before needing repairs.....
Old Apr 21, 2005 | 03:38 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Haynes?, Chiltons?, BAH!
My Chilton manual says how adjust valves from cylinders 1, 5 and 6, but nothing about cyl. 2, 3 and 4. These valves are auto-adjustables or what?
My V6 family car has 240.000 kms with the stock timing chain and no problem with this stuff.
Denis V.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
