not running very well
Old Apr 17, 2005 | 05:38 PM
camarodude91's Avatar
Ok I just picked up another 91 RS. My problem is that the engine wants to rev way to high all the time. It won't idle and when I'm driving it it pretty much redlines itself. I did find out that the erg valve was completely off. So i have a hugh exhaust leak and the tube going to the throttle body is cracked. I tried to put the egr back on with a new tube but the exhaust manifold is stripped. Also the gas pedal feel like it's stuck when the engine is running but when it's off it's fine Can anyone think of what the problem could be from?
Old Apr 17, 2005 | 06:38 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i had an issue like this . kinda. once the engine is on and "reving all to high" open the hood and examine the throttle arm on the .... whateber the throttle is connected to. physically close it. does this help? if yes, replace your throttle return spring, throttle cable (was the ussue with mine). if no then, um.... i don't know. hpe this helped a little
Old Apr 18, 2005 | 03:29 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I also had a similar reving problem. I changed the throttle position sensor and the air valve control sensor (its part of the throttle position) and I cleaned the throttle body, damn was it dark as hell.
Old Apr 19, 2005 | 11:24 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
If the EGR tube is not sealed on the Intake, that's your problem. It's a HUGE vacuum leak and your car is trying to compensate for it, but can't. The MAP sensor is seeing low vacuum, so it thinks that the throttle is opening so it gives it more injector pulse width(more fuel), the RPMs go up and the cycle continues until the leak can't flow anymore air into the system. You probably have a SES light on too if you can get it to sit long enough, probably a TPS code.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
