Can't Get My Rotor Off!?!?!?
Old Apr 20, 2005 | 03:30 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i am changing out my distributer cap and rotor, i got the cap off no problem, but i am pulling on that rotor awfull hard with no luck, i don't want to break anything. please someone help me.
Old Apr 20, 2005 | 04:26 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I had the exact same problem when I did my tuneup. What I finally did was clam a vise grips on the base of the rotor and twist gently to break it and pull the pieces off. Use only the minimal amount of clamping force so the jaws don't slip, and you shouldn't have to twist very hard. You could perhaps also tap it with a hammer to break it off, but I haven't tried that.
Old Apr 20, 2005 | 05:28 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
try spraying a lil liquid wrench or pb blaster on it , it should just pull out.
maybe clamp vice grips on it and tap the handle of the vice grips
Old Apr 20, 2005 | 10:11 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
just take a big screwdriver and use the handle to tap the rotor, should take 4 or 5 taps and it'll be ready to come right off
Old Apr 20, 2005 | 11:15 PM
Xophertony's Avatar
Axle/Gears: n/a
am i suposed to crawl under the car or do i tap on the top of it?
Old Apr 20, 2005 | 11:20 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
just tap on the top of it, let the weight of the screwdriverdo the hitting, and it'll come right off. atleast mine did took me 6 hits
Old Apr 21, 2005 | 03:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Go ahead; crack the rotor off; you're replacing it anyway. It's just plastic; the shaft is metal.
Old Apr 22, 2005 | 02:01 AM
Xophertony's Avatar
Axle/Gears: n/a
Originally posted by TomP
the shaft is metal.
thats what i needed to hear.
Old Apr 23, 2005 | 11:47 PM
KED85's Avatar
Yeha those boogers do stay ontheir
Do what ever it takes to "break it off" cause yes the shaft is metal.
BUT be gentle in your methods due to the damage to other things in the area!
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
