Engine clean up...have EGR delete, how to remove the solenoid & simplify vacuum lines
Old Apr 25, 2005 | 11:40 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
My EGR is gone, but I had no real idea what vacuum lines were still necessary, so I kept them all and just bipassed where they normally ran into the EGR.
So has anyone eliminated the EGR and all its vacuum lines? What did you do with the blasted solenoid. I'm sick of looking at the darn thing. But I don't want the car to code!
Some of the lines run to the Charcoal canister...I know this filters out fuel vapors, but can I eliminate it, or at least uncomplicate the vacuum lines where they all run
Old Apr 26, 2005 | 11:54 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
What emissions code are you running? Mine is a ZCD and I may be able to help a bit. I've had to really simplify mine for the 3.1 swap since the shop that did the swap did the swap wrong...
Can you get a pic of the emissions hose routing sticker if the code is different? I can use that to guide you through this.
However, getting rid of the solenoid is a different problem altogether. The black box that it's attached to has to see vacuum when the solenoid is triggered or it will set a code. I'm not sure as to whether you can just run a single vacuum hose to the sensor or not, and if you do, whether it still sets a code or not.
Old Apr 26, 2005 | 03:24 PM
LT1guy's Avatar
Car: 1987 Trans Am
I used a resistor in the wiring harness plug on my SS when I was running with no EGR solenoid, and it cured the coding problem on that car, but I don't remember the resistor value (got the tip from CamaroZ28.com).
Edit: I did a search on CamaroZ28, a 68 or 75 ohm resistor should work fine on an LT1...I bet it would work on the V6
http://web.camaross.com/forums/showt...enoid+resistor
Old Apr 28, 2005 | 11:34 AM
redraif's Avatar
No sticker...was gone before I even bought the car. I just wondered which lines were egr only and which were vacuum lines for other things. I can eliminate all the EGR only and reroute the OTHERs that are still necessary
Old Apr 28, 2005 | 12:28 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, I have a pic of mine, but it's on my other PC and I have no way to transfer it to this one (it's a bit too big for a floppy).
The best thing I can say is that there are two lines coming out of the junction block on the throttle body. IIRC (it's been a while since I had my 2.8) one is for the fuel pressure regulator, that one should be the longer line in the middle, and the one the EGR is T-d off of is in the other port. These lines are really very breakable so be careful. I'll see if I can't get the pic transferred somehow so you can see what I'm talking about...
Old Apr 28, 2005 | 12:42 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Pic was a bit smaller than I thought...
Attached Thumbnails Engine clean up...have EGR delete, how to remove the solenoid & simplify vacuum lines-carpics0013.jpg
Old May 2, 2005 | 02:43 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
does anyone else only see the top 1/32 of that picture, i do not see the whole thing?
Old May 2, 2005 | 06:36 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yeah, I do... I'll have to see if I can't get this damn PC to load it right...
Frozer!!!
Jan 19, 2024 04:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
