V6 volt meter gauge...
Old Apr 27, 2005 | 06:03 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
How accurate are they?For instance,I can be driving at night and the gauge is alittle below 13 volts.I can adjust the dash lights all the way off and the volt go up to about 14 or so volts again.Sometimes if I'm idleing,with my laptop plugged in my lighter socket,the gauge will fluctuate between 13 and lower volts.I put a multimeter on the battery while the car was running,and it showed 14.4 volts with the lights on and radio on as well(no amps,just stocksystem).Can it be the contacts in the cluster are getting old and/or oxidized?
Ken
Old Apr 27, 2005 | 01:51 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Could very well be
Old Apr 27, 2005 | 01:58 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
it could verywell be deterioated at newest of your on the right board your car is 13 years, old plenty of time for corrosion
Old Apr 27, 2005 | 02:36 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
The same thing happens in my car and I have an aftermarket cd player and an amp. It does the same thing without the amp. I also took a multimeter to the battery and read a little more than 14 volts. You're not the only one.
Old Apr 27, 2005 | 04:12 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I always thought the gauges in our cars were inaccurate. I know the tach's are off, the fuel gauges are like a suggestion of what you could potentially have for fuel so I figure the volt meter and everything else is off as well.
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
