Code 32????
Old May 9, 2005 | 05:22 PM
confucius101's Avatar
Code 32 now what????
ok so i've just pulled a code 32
from the computer but now what do i do?????
should i just go out and replace all three parts or what???
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
sorry i'm still very new to all the inner workings of cars and my babe has got some real issues that i need to resolve soon......
Old May 10, 2005 | 10:28 AM
ANYBODY????
Old May 10, 2005 | 10:45 AM
A friend of a friend came by (i know i know but every shop i've been to has said that there is nothing wrong and i'm rish b/c of the headers) to read the computer for me just to double check this out for me and pretty much said that it's cost me just on time alone........ the guy tunes car's for a living and bills @ just over 250 hr.......
he said the car is jumping all over the place and dumping gas stright out the rear (this i knew b/c i'm only getting around 8MPG)he pulled the plugs and all they show is that i'm running lean wires are all new (2months) and i need a new cat......
so he said he can start work as soon as this weekend @ 150 hr but that he won't collect anything untill he get's the car running better then new
Old May 10, 2005 | 11:08 AM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
Code 32 is an EGR failure. Check all the plastic vacuum lines for cracks. Sometimes slow or very unresponsive o2 sensors will cause this and will also cause the problems you are describing.
BTW an engine dumping fuel out the tail pipe is rich not lean. Ya know the dealer will only charge you about $100.00 hr. $250.00 an hr. seems a bit steep to me.
Old May 10, 2005 | 12:55 PM
ok sounds like a start thanks....
would anyone happen to have any kind of map showing all the vacume lines ????
as for the cash well i've actualy gone to 1 dealer ship and they guy's there didn't seem to know anything more then i do about these cars so i think i'm gonna stick with this guy for awhile b/c he loves them almost as much as we all do... and i'm sure i'll be able to work something out with him as far as a final price
thnaks again
i'm off to search the boards........
(one of these days i gotta go buy a manual or two )
Old May 10, 2005 | 02:02 PM
Car: 88 RS
Check the tuneup decal on the hood
Old May 10, 2005 | 02:06 PM
aftermarket hood
Old May 10, 2005 | 02:13 PM
86BLUEBIRD's Avatar
Car: 86 Firebird 2.8
Engine: 2.8l v-6
Transmission: auto
go to autozone.com and the repair guides it should have a diagram of the vacuum lines for your car
Old May 10, 2005 | 02:16 PM
THanks
Old Jun 14, 2005 | 01:53 PM
KED85's Avatar
Here is a 1985 smog hose set up
IF your car is NOT a 1985, your set up will be different.
But this may be a foundation to offer you.
I never saw you mention what year is your car.
Attached Thumbnails Code 32????-85-20firebird-20smog-20routing
Old Jun 14, 2005 | 02:46 PM
hey ked sorry she's a 91 3.1...........
Old Jun 14, 2005 | 04:44 PM
KED85's Avatar
In the smog set up yours is worlds different!
You do have that electric EGR set up.
And that's an expenive item to replace.
I would remove it, clean all passages, new gasket & see what happens.
I also hear that the FWD 60* V6 Stage Two or Gen Two EGRs are the same.
But your problem helped me I think.
I've been told my vacuum hose routing is backwards there.
This may be the cause of my cold morning early morning bucking....
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
