Quick Intake question
Old May 17, 2005 | 01:51 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
What is the name of the part that connects to the cylinder heads and directs the air into the cylinders? I need to replace mine. I went to the junkyard asking for a manifold and the guy came back wiht a lower plenum and said it was the manifold.
Old May 17, 2005 | 03:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
guy @ junkyard is correct.
maybe a pic of what you want replaced will help better.
Old May 20, 2005 | 06:58 PM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
according to the haynes manual, you are looking for the 3rd part of the intake "manifold" the actual manifold itself. according to the book, the 3 parts are upper plenum, lower plenum, and the manifold. the manifold connects the upper plenum and the heads and the block together just like the intake manifold on a v8 does with the heads, the block, and the carbuerator. just tell the junk yard that you want the intake manifold for your car. they normally don't know the difference!!!!!
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
happyhapka
Aug 15, 2015 04:42 PM
