___$436.00____
Old Jun 2, 2005 | 03:59 PM
confucius101's Avatar
___$436.00____
for an EGR valve WFT???????
i'm still tossing a code 32 so i figured i'd just replace the valve and hoses but they want 436 for the valve alone
come on guys talk to me here i know that there has to be another way for a heck of a lot less.......
Old Jun 2, 2005 | 04:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
mine from zone was around 200.
It blew not long out of warrany. So now I have this litte plate of steel, and it throws a SES light once in a while.
Old Jun 2, 2005 | 04:17 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can try to clean it (never been successful), shell out the 200 or so or live with the SES light. As long as you're not getting detonation at part throttle cruising you should be ok.
Old Jun 2, 2005 | 04:43 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
WTF! It was for my iron duke but I was quoted 52 bucks for an egr, why so expensive??
Old Jun 2, 2005 | 06:39 PM
naf's Avatar
naf
Digital valve. Can vary amount of recirculated gas.
Old Jun 2, 2005 | 07:00 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I need to replace mine just cant afford it but if i set a code 32 once every now and then i dont care.
Old Jun 2, 2005 | 09:28 PM
naf's Avatar
naf
It goes away if you ignore it. No worries.
Old Jun 2, 2005 | 09:49 PM
Car: 95 Z28
when I got a code 32 I took it off, soaked it in carb cleaner, and it never came back :shrug: Carb cleaner rules, I cleaned my IAC on my truck and it worked like a charm, 1 dollar fix
Old Jun 2, 2005 | 09:51 PM
FAST RS's Avatar
I think soaking in in carb cleaner would fry the electronics in it.
Old Jun 2, 2005 | 09:54 PM
Car: 95 Z28
gotta love my primative one then I guess
Old Jun 2, 2005 | 09:56 PM
FAST RS's Avatar
Ya i wish i had the old style one i would have replaced mine by now since the old ones are very cheap.
Old Jun 3, 2005 | 08:07 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
*cough* i have a couple of used ones.
Old Jun 3, 2005 | 09:23 AM
well i just found one for 240 so i guess thats have to do....
i've been running about 8 mpg for about a year now
and it's dropped down to about 5 as the car is now driven every day.....
the only code i'm getting is a 32 so here i am
aim talk to me about the used ones....
Old Jun 3, 2005 | 09:26 AM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
<making note to self> next time i need a part that i s really expensive or i can't find, gonna email AM91!
Old Jun 3, 2005 | 09:40 AM
Car: 91 Camaro
5 or even 8 mpg should not be caused by a bad egr! i'm not running an egr and even with my cam and everything else i have, i get 15-16mpg city and 25-26 highway cruisin at 3200 rpms (3.73 gear).
Old Jun 3, 2005 | 10:01 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
yeah, if you're getting only 8 mpg, you have some other SERIOUS problem that you have to look into.
Old Jun 3, 2005 | 10:27 AM
naf's Avatar
naf
5-8 mpg? Take the money for the egr valve and find out what your bigger problems are.
Old Jun 3, 2005 | 12:00 PM
Dale's Avatar
Engine: 350 S-TPI
yea, I dont have an egr and still getting mid teens in town hotrodding.
5-8 a gallon. Thats worse then a hummer
Old Jun 3, 2005 | 12:45 PM
yea were going to run a compresion test this weekend alone with a tune up, breaks & rotors, and i just figured i'd see what else i could do but i'm not willing to put too much $$ into the 6 at this point........ i just found an ls1 with wires & tranny for 2000 so i think i'm just going to go that route but even that will hvae to wait at least 6 months or so
Old Jun 3, 2005 | 01:43 PM
Car: 91 Camaro
tune up might help. definately look into (think about) your cat...maybe its clogged. um....air filter should be part of your tune up... injectors might have problems. o2 sensor could be bad but not throwing a code for some reason. it could be one of several things but there definately isn't any way that you should be having to suffer with 5-8 mpg!
PUNISH3R
May 14, 2012 05:31 PM
JBMChump
Exterior Parts for Sale
Sep 13, 2011 05:03 PM
Strunthopht
Jun 17, 2004 04:55 PM
L2R
Dec 30, 2001 04:29 PM
