timing distributor
Old Jun 2, 2005 | 09:03 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
timing distributor
Hey on my 1991, v6 3.1 camaro rs i have to replace the timing distributor, not just the cap and rotor, how long do you think this will take? Has anyone done it before? so i can get input from past experiences
thanks
Old Jun 2, 2005 | 09:30 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
You can rebuild your distributor, all the parts are available from GM. Its not necessary to replace it. When my ignition module burned out in March, I pulled the distributor and rebuilt the whole thing: new module, pickup coil, disassembled and cleaned the center shaft, cleaned and adjusted the reluctor, rotor, cap, (along with: new AC Delco plugs, new AC Delco premium silicone wires, fuel filter, K&N air filter, AC Delco thermostat, Gates belts... sounds like a TomP tune up!) My motor is back to it smooth muscular self. Do a search for KED's thread on the V6 distributor rebuild.
Old Jun 2, 2005 | 09:44 PM
tourville's Avatar
Car: 1991 Camaro RS
cant find it :\ still searching tho
Old Jun 2, 2005 | 09:50 PM
tourville's Avatar
Car: 1991 Camaro RS
found it
https://www.thirdgen.org/techbb2/sho...ibutor+rebuild
tourville's Avatar
Car: 1991 Camaro RS
found it
Old Jun 2, 2005 | 09:55 PM
oldschool's Avatar
Engine: 2.8 LB8 HO
Great! Its not hard. Just do a carefull complete job.
Old Jun 3, 2005 | 12:20 PM
tourville's Avatar
Car: 1991 Camaro RS
thanks!, ill be careful!! not doin it for a little while but i will be soon ;o
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
