TPI testing?
Old Jun 4, 2005 | 05:14 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
TPI testing?
i could swear i read a post about this a few days ago, but upon searching i found nothing. so how do i test my TPI?
i will have the uper plenum off to re-rout the vacuume lines that go through there tomorow aand figured i ought to do this at the same time, since you need to pull the upper plenum to get to the TPI (right?)
if anyone could explain this i would realy apreciate it (or link to that other thread i am thinking of) keep in mind i am volt-ohm meter illiterate.
thanks
Old Jun 4, 2005 | 06:13 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
tpi? TPI?
what part(s) are you calling tpi? the fuel block w/injectors & fpr? man, if it weren't for teh bucket sub I 'd have to smack you
Old Jun 4, 2005 | 02:26 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i think he means tps
Old Jun 4, 2005 | 02:29 PM
Xophertony's Avatar
Axle/Gears: n/a
TPS. perhaps that is why i could not find what i was looking for. oh and project, don't bother i just smacked myself
so if anyone knows that would realy help.
Old Jun 4, 2005 | 02:45 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
here this might help mostly anything you can find out about cars
AARC
You might need this go in to Auto Repair Reference Center
Password: PL321145321
Old Jun 4, 2005 | 02:55 PM
Xophertony's Avatar
Axle/Gears: n/a
GREAT link. but gave like three lines of directions for it. not very helpful.
Old Jun 4, 2005 | 03:51 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
do a search
im serious
Engine: 5.7 / 7.4
but tps is on the tb, and there is a tech article on setting it. Samew w'the tv cable.
1992rs/ss
Jan 31, 2025 05:10 PM
Jae992
Aug 27, 2015 09:07 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
