3.1 valve cover question
Old Jun 7, 2005 | 11:30 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
im trying 2 take off my valve covers with out taking off the plentem. i saw a topic on here where its do able. but..do 3.1s have studs instead of bolts? because i would HAVE to take em off if i had studs right? just wondering if anyone has had any experence with this stuff
Old Jun 7, 2005 | 12:13 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
yes, typically there are studs from the factory. you can try to get them out if you want then put regular bolts back in.
LT1guy's Avatar
Car: 1987 Trans Am
Its not doable...take off the plenum and runners, and then take off the valve covers. Yeah, its a PITA, but with a stock intake thats how it is.
Old Jun 7, 2005 | 05:31 PM
Car: 1985 iroc-z
yeah....i didnt think i could. i was at work when i thought about the studs. i looked at it afterwards and i saw the studs..kinda sucks..i need 2 adjust my valves. one of em is ticking...but...i dont think all that work and money for gaskets are worth it. the ticking valve wont hurt much, will it?
Old Jun 7, 2005 | 09:50 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
To do your valve cover gaskets, remove the upper and lower intake plenums, and the fuel rail with the injectors. Its the only way to do this job. Also reuse the factory valve cover studs, nuts, and load spreaders. They are superior to ordinary bolts. In fact GM added these parts to the V6 F-bodies in 1986, along with a composite cork gasket to stop valve cover leaks.
Old Jun 8, 2005 | 10:08 AM
LT1guy's Avatar
Car: 1987 Trans Am
Depends on how bad its ticking, and why...is it due to misadjustment, loosening nut, cam lobe going flat?? If its the latter, tightening it won't do any good.
Old Jun 8, 2005 | 10:34 AM
Car: 91 Camaro
...collapsed lifter...
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
