testing to identify leaky injector
Old Jun 7, 2005 | 09:11 PM
eddie jr's Avatar
I would like to test my injectors to see if they are leaking (which ones) and heard about removing the fuel rail and sitting the injectors over the holesand watch for drips. Did I hear correctly, can you do this? What about the cold start injector line. Will that move enough when lifting the rail??
Old Jun 7, 2005 | 09:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
close. Remove the upper 1/3rd, pull the rail with fuel lines and injectors still installed. Get some rope or string, and suspend it about 3 inches above its usuall spot, and line its spot with shop towels
Pull the two plugs to your ignition coil.
Hit the key, let the pump prime, turn key back off.
Watch and observe for a good 5 min or so. It wont happen in 10-30sec, it will take longer unless the injector is SCREWED.
Old Jun 7, 2005 | 09:57 PM
eddie jr's Avatar
ok cool, thanks dale What about the CSI line though? won't that be in the way trying to lift the rail 3"? Will it bend that much? Do you leave it plugged in or take it out and put in a plug?
Old Jun 7, 2005 | 10:46 PM
Dale's Avatar
Engine: 350 S-TPI
sorry, forgot about it cause I dont have one. Yes, it will need to be removed from back of intake and lifted with rail. It will need to be checked as well.
db057
Sep 4, 2015 07:57 AM
Justin92GTA
Aug 27, 2015 11:16 PM
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
