Cigarette lighter & hatch release - related???
Car: 1992 Camaro RS
Engine: 3.1L
A few days ago I noticed that my cigarette lighter socket was no longer working (plugged in my usually accessory), and today I come to find out that the hatch release switch on the console isn't working either.
So, I whip out the Haynes Manual and check out the wiring diagrams - I don't see either of these two shown anywhere! Does anyone know if they share a fuse, and if so which fuse that might be? Or is there a common run of wire shared between the two? I ask this because my aftermarket radio was recently stolen, and although the cretins who took it didn't really do any serious damage to the dash, I'm wondering if they might have cut a wire in the process. I've already replaced the head unit, but can get back into the opening fairly easily if need be.
I'm hoping one of you guys knows the answer before I start gutting the interior to check it out!
Car: 1992 Camaro RS
Engine: 3.1L
Originally posted by FAST RS
I think they do share a fuse.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I think it may be your ACC fuse its been a while since i have been down there. I know when my cig fuse went my power doorlocks stopped working along with all my courtesy lights and dome light.
Car: 1992 Camaro RS
Engine: 3.1L
I didn't check if the dome light was working or not - bright sunshine when all this became apparent. As for power door locks, well, this car is pretty stripped down, no power anything (except steering and brakes!). The dash lights do come on though, I specifically checked those.
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Car: 1986 Firebird
Engine: 2.8 V6
Re: Cigarette lighter & hatch release - related???
If your horn doesn't work either then its definately the ACC fuse. You didn't drop a penny into the cigarette lighter, did you? That's a common problem...
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
my stock lighter socket popped a fuse every time i used it. I got one from an 04 escalade and made it fit with a dremel and some black hot glue in the back of it. looked stock and had a nice rubber grip on it.
Car: 1992 Camaro RS
Engine: 3.1L
Found it, fixed it, everything's back to normal. For the record, it was a 15amp fuse in this car. Not sure why, unless it's just because this car has virtually no options on it.
Thanks for the help guys!
Engine: LO3 305 TBI
that should have been a 20 amp fuse, replace the 15 with a 20 or it may blow when you have your doors open and the lighter popped in.
Car: 1992 Camaro RS
Engine: 3.1L
Car: 1986 Firebird
Engine: 2.8 V6
I love having no options; the only two on my car were rear defog and power windows. Actually there was a third; the power antenna, but that's long gone now! I don't even have a hood pop or power door locks or (thankfully!) cruise control.
Car: 1992 Camaro RS
Engine: 3.1L
Originally posted by TomP
Maybe no options meant that got a 15 amp fuse?
A/C, Auto, Cassette, P/S, P/B - where those last two standard equipment?
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
looks like ps/pb were standard.
http://memimage.cardomain.net/member...40_23_full.jpg
look how much that cassette deck cost
, and a/c
, and a/c
Car: 1992 Camaro RS
Engine: 3.1L
, and a/c
, and a/c
Base price of $12,075.00
Preferred Equipment Group $1,085.00
(includes A/C, AM/FM cassette, body side mouldings, color keyed front/rear floor mats)
Auto trans w/overdrive $530.00
California Emission Requirements $100.00
Power Hatch Release $60.00
Total comes to $13,850.00
Destination charge $490.00
Preferred Equipment Group Savings -$550.00 (roughly 1/2 off the above price)
Grand Total: $13,790.00
You know, since that was 13 years ago, and the car has NOTHING on it, that price actually seems high. I'll bet that taking inflation into account, it's really high for such a base model.
Yep, I just found a cool little inflation calculator online, and it tells me that adjusting that price to 2005 dollars would give a sticker of $18,675.22 These days you get a lot more on a car for 18 grand it seems. Of course, you'd have to buy a Hyundai to get it, and seriously, who wants to do that?
http://www.westegg.com/inflation/
Car: check
Engine: check
Transmission: check
Mike, the ACC fuse actually is a 20 Amp'r. The fuse sizes are printed on the fuse box next to each one. As for the problem of the ACC fuse blowing, it may be due to the cigar lighter itself. Mine now resides in the console as it blows the fuse whenever it is in place.
The body of the lighter shorts out the socket and takes out the fuse. I figured it out one dark night when I put the lighter back into the socket and saw it sparking. Then found the ACC fuse blown, again. I've also seen this same problem on other GM vehicles.
RBob.
RBob.
Car: 1992 Camaro RS
Engine: 3.1L
RBob.
RBob.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
