air intake
Old Jul 3, 2005 | 02:10 AM
mmadreman's Avatar
Car: 88 camaro
Engine: 2.8 mpfi v6
Transmission: 5 speed
air intake
88 2.8 mpfi...... i have the duel snorkel intake now with two k&n filters. at the bottom of the air box i cut it off flush, and made a duel ram-air intake.my question is,is there a difference between that or just doing away with the duel snorkel set-up , and go to a single cold air intake?
Old Jul 3, 2005 | 02:15 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have had both and think both ways are equal but i do think the dual snorkel intake would work better since air is being pushed into it.
Old Jul 3, 2005 | 02:22 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
The dual snorkel is a cold air intake, and is what most people try to get if they don't have it. As a matter of fact, the Firebird guys are always complaining because they can't use it, no clearance with their hood. The real restriction for our engines is the size of the passages in the plenum on the other side of the throttle body. The dual snorkel can flow more air than the stock plenum can. You've already done as much as you can for the intake side, without getting a bigger plenum and throttle body.
Old Jul 3, 2005 | 02:23 AM
mmadreman's Avatar
Car: 88 camaro
Engine: 2.8 mpfi v6
thanks, another thing? how much restriction do ya think the 90 degree elbow's create on the intake of air?
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
