fuel pump for carb...
Old Jul 4, 2005 | 10:25 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
HI,
I posted this also on the carb page...
I am changing my motor from a mpfi 3.4 v-6 (currently for sale on ebay...what a deal!) to a carbed v-8 (sorry) and was wondering if I can use an aftermarket electric fuel pump to pull gas through the tank pump or if I will have to use a special return-type regulator with the in-tank pump.
Thanks.
Old Jul 4, 2005 | 10:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm doing the same thing & people keep saying to use the mallory 3port w/bypass. $75 for it but seems to last longer than the 2port &using the second port for teh return. A couple posts on thins in the engine swap forum.
Old Jul 4, 2005 | 11:13 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Shameless ebay plug
Old Jul 5, 2005 | 07:06 PM
KED85's Avatar
Here's the deal with what I'm doing (3.4 & using a Carter electric fuel pump to pull gas, this is the 85 Blazer 2 se Carb'd conversion).
I asked & scoped out options...
To regualte the current what ya got down to the 5PSI ya need to NOT BLOW OUT THE JETS OR SEALS, the regulator is expensive.
Available but expensive.
What I'd suggest is other tank for the project & hook up electric pump OR even wiser is the TBI fuel tank & it's pump & a regulator & that'll give ya constant & lower pressure.
Me?
I'm hoping to just install a TBI (12-14PSI) pump in my 85 Blazer tank & be done with it. I already have the regulator.
As with your V8 conversion, new stuff must be engineered.
Old Jul 5, 2005 | 10:34 PM
Car: 91 RS,
Engine: 406ci
Oh, that Ebay thing must have just slipped out...ha ha.
I did a tpi to carb swap a few years back and used the mallory 3-port regulator with tank pump. It worked good once I got it to stop leaking. But with that route I'd be at the mercy of a 16 year old pump.
Old Jul 6, 2005 | 05:07 AM
KED85's Avatar
On my set up I used the carter pump, a filter before the pump and after the pump,
I found a 3 way fuel filter, the one line used as a return to tank line. Then the regulator.
Works fine no leaks.
My thinking is low pump (what 7 PSI max?) pressure is the key for my no leak set up.
Once I get more bugs sorted out then I feel safer using/converting to a TBI pump in tank using same filters & regulator
Old Jul 6, 2005 | 06:08 AM
Car: 91 RS,
Engine: 406ci
Would ANY tbi pump work (from a van, etc)?Do they all have similar pressure?
Old Jul 6, 2005 | 06:17 AM
KED85's Avatar
Assembly MUST FIT TANK
Get a TBI set up from F Boody & ya good to go.
Ya thinking of swapping the pumps onto your current assembly?
Why not give it a try?
I'm using a TBI assembly from S Series to make into my TBI set up for my Blazer tank (they different style tanks & different length assemblies)
Here's pic of my set up now & leak free.
Old Jul 11, 2005 | 07:40 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
sorry to sound stupid but why not hang the mechanical pump to the block like any normal carbed car has.........? then it'll only cost like $30.....or even go with a holley or the likes for what $100 to $150? Y'all like to be complicated....lol
Old Jul 11, 2005 | 08:21 AM
KED85's Avatar
You'd have to own one to understand why it's wise to not "go original".
Bad design.
And if ya knew, 3.4 has NO mechanical fuel pump attachment ability.
This is temporary until I install the factory TBI assembly into my gas tank.
Still regulating it down to necessary 5PSI.
Old Jul 11, 2005 | 09:50 PM
Car: 91 RS
Engine: 5.0 tbi
No....wait.....I was talking about the guy with he V8 carb or did I read wrong?? But even still go with holley lol.
Old Jul 11, 2005 | 11:27 PM
Car: 91 RS,
Engine: 406ci
there is no provision for a mechanical pump on later smallblock motors, otherwise I'd just use one.
Old Jul 12, 2005 | 08:26 AM
Car: 91 RS
Engine: 5.0 tbi
ok.....you didn't say it was a gen 2 block, I don't know if it'll work but jegs has a carter electric pump that runs 4 - 6 psi. like I said though no idea if it'd work for ya but check it out if ya want.
Old Jul 12, 2005 | 08:54 AM
KED85's Avatar
That's the pump I have in my picture!
Old Jul 12, 2005 | 11:49 AM
Car: 91 RS
Engine: 5.0 tbi
oh lol. I tried
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
