Hydrolic Problems
Old Jul 11, 2005 | 01:48 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Hydrolic Problems
Before, my screwed up Clutch pedal felt like when you sit in the car and pump the brakes, like a hard brake pedal. But yesterday we went to go play with it and see what the problem is, and when we pushed hte clutch pedal it made a pop sound and then went all the way to the floor. There is now no resistance in the pedal but under the hood is a fluid moving sound. I dont see any fluid leaking or anything but it deffinatly sounds like busted lines or something.
I have looked at autozone and the Master Cylinder for clutch is $35 bucks, and the Slave is $35 too. I dont think theres anything wrong with my master, can I just get a slave and some new lines and hook it up to that? I gotta get this thing runnin again and spend the least amount possible
Old Jul 11, 2005 | 03:46 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Sounds like you had a binding clutch fork, and when you pressed on the pedal, the slave cylinders actuating rod popped off the fork. I would take the trans service cover off (right where the bellhousing meets the engine on the bottom) and look in there. I'll bet you find your problem.
Old Jul 11, 2005 | 03:48 PM
Car: 95 Z28
It didnt pop off the fork, I looked at it. How can a binding fork be fixed? Do I gotta pull the stupid tranny back out? :'(
when I look in that cover all I see is flywheel, its tight up against it. What I'm thinkin is I can pull the fork boot off and see :shrug:
Old Jul 11, 2005 | 05:33 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
Transmission: 5 speed
sounds like the slave cylinder...theres a hose that goes to ur brake booster check that out once, there may be fluid leaing out of there, if so there the prob. Also, just so ya kno if you need ot replace the slave cylinder do it urself, the garage will charge close to like 400 in ****in labor
Old Jul 11, 2005 | 05:56 PM
Car: 95 Z28
ya I know about that. I duno if you've seen em but I have several threads about the ton of crap I've done with this transmission lol.
My question was can I replace just the slave or does the master have to be changed too? its a seperate thing from the Brake Master Cyl. And autozone sells em seperate and they're 40 bucks a piece. Can I just use my old Master?
Old Jul 11, 2005 | 11:02 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
no ya dont have to change the master cylinder, onlly problem is, well this is what my mechanic told me, is that you can only get the slave cylinder from GM. which is like 175? I just did one on my car
Old Jul 12, 2005 | 12:06 AM
Car: 95 Z28
No, its $35 at autozone like I said 3 times before lol. I'll go look into that this week then
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
