spent 10 bucks for 1hp end up costing me $224
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I recently did the tb bypass and when my dad was pulling the old hoses off he broke the piece that screws into the intake manifold which end up costing me $224. And the mechanics there got rid of my tb bypass and send it will mess up my engine. What should i do, do the tb bypass again for the 1hp or listen to the mechanics at the garage and keep it how it is stock?? I live in southern maryland it is never really cold so i dont see how they can say it will hurt the engine. Also does anybody have pics of the tb bypass they did so i can see that i did it right. (im 99% positive i did it right and they just want the extra money so they told me that it was hurting the car)
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Originally posted by V8 Slayer
Just leave it dude,the 1 HP is not even worth opening the hood for...
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I did it because it was cheap and i was bored one day. Didnt notice a difference really maybe better throtle response but thats about it.
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
At least you won't have that connector, that you just had replaced, break while you're on the road somewhere.
Car: 1992 Camaro RS
Engine: 3.1L
Heh, you'll see a bigger gain in HP when comparing a cold fall day to a sweltering hot summer day.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Wow. $224? I broke mine, and replaced it for $10 from some galvanized piping... I think it was 5/8" or 3/4" pipe thread?
Car: 1987 Camaro
Engine: 2.8 soon to be 3.1 Twin turbo
Axle/Gears: No idea ATM
i broke that lil piece of piping too, it was stuck in there and couldnt get it out without disassembling the engine, which i didnt feel like doing, i went out and bought a used engine and tranny with 100k(75k less then my old ones) on them for 300 buxz and am about to do a swap ,but yea braking that lil piece of piping deffinitly sucks more c*ck than paris hilton
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
sounds to me that someone got bent over and raped by a shop...
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
you probably wont see a gain in a little V6. In a larger engine you do, but not in yours. No it wouldn't hurt your car, unless you live in antartica, in which case it MIGHT be a good idea. Other than that, GM running hot coolant through the throttle body is dumb.
Car: IROC Z
Engine: 5.7
Car: 1987 Camaro SC
Originally posted by Dale
When I pull on a hose, it doesnt come off, I take a razor blade and cut the hose. It comes off much easier then.
If you need to reuse the hose. Push on it like you are putting it on and twist until it breaks loose. Then wiggle it back and forth while pulling. If you pull straight on the hose you just make it stretch and grip the tube tighter. Know what a Chinese finger trap is?
Car: 87blueracr
Engine: u know them
Transmission: u got it
speaking of, i can't get mine off, and i unhooked everything, the only thing i haven't tried is to put a bar in the intake hole and pry upwards, is that common on theese things??
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Originally posted by KED85
Think how much fun you could have had with those Maryland Women for that $224...
I would have been partying in DC, again, all night & morning long.....
Where in SoMd? I lived there from 80~93 and still go there to see best friend. He/we know of plenty of salvage yards for parts if you need.
Car: 87blueracr
Engine: u know them
i legpress 450 and i was using all my body weight, still couldn't get it. i need the old one off for when the trueleo gets here in a couple of weeks. i think i am gonna get the 4' diggin iron and try again when i get back off the water in a week!
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
project 85 2.8 bird, I live in waldorf charles county, md. This thread is over now lol i went to pick up my car today and i talked to the mechanic and he told me he left the tb bypass on and told me the other guy didnt kno what he was talking about that said it would hurt something and was gonna replace it to stock. I didnt notice any gain with the tb bypass. I ended up spending $444.53 on getting 4 new tires mounted and balanced, tighten loose knuckles in the steering column and replacing that piece that broke.
I ended up spending $444.53 on getting 4 new tires mounted and balanced, tighten loos knuckles in the steering column and replacing that piece that broke.
I could have been missing for days with that money & with those DC Maryland Virginia Women!
And smiling when ya found me......:>
Engine: 5.7 / 7.4
14th street cruising.
I lived in Port Tobacco & Welcome, past La Plata on rt6 west.
Andrewes Auto Parts. They usually have what you need. If not, Brandywine Auto Parts up in.........Brandywine. Use their locator service. I did when I was up in Minot ND.
Car: 87blueracr
Engine: u know them
dead but smiling alright, and then we wouldn't have ked to give up his old school tips that all us young guys forgot about or didn't get taught.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
gixxer92
Sep 1, 2015 04:32 PM
