How many quarts of oil in 3.1
Old Aug 11, 2005 | 11:58 AM
Firebat's Avatar
How many quarts of oil in a 3.1 V6 do you put in when changing oil. I usually put a little less than 4 quarts in. Just wondering what the EXACT recommanded amount is...
Old Aug 11, 2005 | 12:18 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
I believe its around 4 quarts.. although that is pulling it out of my head... i might take a look at my repair manual after i get back today
Old Aug 11, 2005 | 12:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I put 5 with the big fliter, and its a bit much.
So I'm going to say 4.25 with reg filter.
Old Aug 11, 2005 | 02:08 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
4.5 qts.
Just put 5 in tho... .5 qts won't hurt
Old Aug 11, 2005 | 02:55 PM
Firebat's Avatar
big filter??? part number please?
Why are you using a bigger filter?
you sure about that many quarts in a 3.1 V6? I was thinking more like 3.75 or something like that... the engine shows its full at less than 4 quarts.
Old Aug 11, 2005 | 04:24 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
just did my 2.8 today, put in 4 quarts with the bigger filter and its full on the dipstick. i plan on checking again before i start it up, cause that doesnt seem like enough oil, but whatever.
edit: gm service manual for an 89 says 4 quarts.
Old Aug 11, 2005 | 04:26 PM
Firebat's Avatar
alrighty. but whats with the "bigger" filter? You mean longer? Now that i think about it there was a shorter filter on the car before i bought it...
Old Aug 11, 2005 | 04:35 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
PF52 filter is the one they are talking about, longer than the stock filter. Holds almost 1 quart.
I never paid attention to how much I put in, I always get the 5 quart jug, and check the dipstick after dumping half in, then just keep topping it off til full. There is always some left in the jug...
Old Aug 11, 2005 | 05:58 PM
Firebat's Avatar
oh. i've been using ph3980, i think? The one that was on there before before i bought it was 1/2 the size of that.
So theres a small, medium, and large oil filter. just like mcdonald's fries...
Old Aug 11, 2005 | 07:31 PM
bru333's Avatar
Car: 1987 Camaro SC
The PH3980 and PF52 are the same size, just different brands.
The stock filter is a PH3387A or PF47, much smaller.
Old Aug 11, 2005 | 07:48 PM
Naft's Avatar
yah the ph3980 is fram, thats the one ive got, not sure what brand the pf52 is.
Old Aug 11, 2005 | 08:45 PM
Dale's Avatar
Engine: 350 S-TPI
pf52=acdelco/gm
Old Aug 12, 2005 | 11:05 AM
KED85's Avatar
For me, I've always tossed in four quarts.
"Some" leaks out anyway thru gaskets.
Always used the AC Delco PF51 until "they" changed over to the PF52, AC Delco brand.
Never knew there was a "smaller size" filter.
Old Aug 12, 2005 | 02:54 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
wha?
maby your gaskets not mine!!
Old Aug 13, 2005 | 09:18 AM
KED85's Avatar
I'm redoing my covers & gaskets with Fiero covers shortly.
Adding a bit of oil every now & then is way more simple than changing those gaskets right now.
I already tackled the timing chain, rear main seal, rear cam seal, oil filter housing gasket & distributor gasket.
If ya wanna come on by & do the job for me, tho, no complaints from me!
Old Aug 13, 2005 | 06:04 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I awalys use 5 qts.
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
88CamZ
Oct 8, 2015 10:29 AM
skinny z
Oct 5, 2015 06:23 PM
