1.6 rockers
Old Aug 20, 2005 | 06:33 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
1.6 rockers
Looking into a set of 1.6 roller rockers. I know I will need a new valve cover. As anybody seen aftermarket valve covers for this engine? How well will 1.6s respond to an engine with stock internals or should i get 1.52??
Old Aug 20, 2005 | 07:23 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You can get the hard to find fieros.
Eldabrock makes some
mr gasket made some
I'm sure a few others do too.
Simulation programs show 1.6 rockers add about 3hp, and 1tq.
Old Aug 20, 2005 | 07:41 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
dont forget lower oil temps
Old Aug 20, 2005 | 08:37 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
how would rockers lower oil temps??
Old Aug 20, 2005 | 10:57 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Possible - due to less valvetrain friction
Old Aug 21, 2005 | 12:01 AM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Dale I noticed you have 1.6s. Just curios where you found your valve covers??
Are the stock valve covers just not tall enough or do they need to be wider too? I was thinking about cutting the valve covers near the base and welding some slighlty taller walls to it. Fabbing a set up shouldn't be too hard.
Old Aug 21, 2005 | 01:58 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
if you get aluminium, they are also lighter allowing for faster reving
Old Aug 21, 2005 | 12:34 PM
Dale's Avatar
Engine: 350 S-TPI
I have fiero valve covers (go to my site, you can see them, as well as my latest post about lb8 intake). You need height, and not alot more. Like maybe .25". I've been told double gasketing makes it clear, but risk more leaks then this setup is already known for.
My rockers are catpep rockers, slightly modified.
reading in the v8 section, some people dont recommend aluminum rockers as I guess the heat tends to make them warp and get brittle and snap.
Old Aug 21, 2005 | 12:36 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i was reading this aswell actually, so i guess forget what i said about the aluminum ones
Old Aug 21, 2005 | 02:47 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
may the design is crappy forthe rockers. I seriously doubt that the heat in the rockers location will fatigue them that much/fast. Also, what brand are these failures happening & how lift is being induced?
Old Aug 21, 2005 | 07:46 PM
Dale's Avatar
Engine: 350 S-TPI
nate, I didnt pay that much attention.
If your really interested and have time, search in the v8 section.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
