Odd trouble code...I'm lost
Old Aug 28, 2005 | 11:00 PM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
I have a carb'd 2.8 '84 Camaro w/ a trouble code "54". Now, I've done the search bit, and what I came up with doesn't fit. Code 54 says: Low fuel pump voltage
OR: Fuel pump relay
OR: Quad Driver Module (QDM) output failure
Now being that this it a carb'd engine, with mechanical fuel pump, it cant be a fuel pump relay, or low fuel pump voltage, which leaves Quad Driver Module (QDM) output failure. So, WTF is the QDM????? It seems to run fine, as good as a carb'd 2.8 is going to run, LOL! What am I looking for here
Old Aug 29, 2005 | 07:17 AM
KED85's Avatar
I would try other sources for your answer
Wish I had not put my shop manuals into storage or else I'd search in my Helms manual for ya.
I'd also try clearing the "codes" and go driving for any changes in ECM readings.
Old Aug 29, 2005 | 09:12 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Mixture Control Solenoid Problem. The MC driver circuit has a Open, short, or ground somewhere in it.
Old Aug 29, 2005 | 01:02 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
2_point_8boy is the winner
Either the MC solenoid is shot, or the controller for it is dead.
Old Aug 29, 2005 | 01:50 PM
CHVYPWR's Avatar
Great, thanks for the info! Now, what/where is the controller for this? The carb looks to be faily new, it's definently not the original. I'm currently missing the air cleaner assembly for this car, is the controller possibly the part in the side of the air cleaner housing that the two vacuum lines connect to?
Old Aug 29, 2005 | 08:56 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
The controller is part of the ECM. It's all computer controlled. My bet is that the MC Solenoid itself is dead. You can get a new one from the autoparts store and make sure that you get the special little ruler that you use to adjust it. It's maked in 1/32" so that you can adjust it right. If it's not adjusted right you'll run rich or lean all the time because there's not enough travel in it to switch between the 2 like it should.
Old Aug 30, 2005 | 09:06 AM
KED85's Avatar
When ordering these parts, make sure you have the carb numbers, too.
They are verticle on the body area.
And do the best to determine you do have the original proper carb now on car.
It may have been switched which accounts for the code and lack of drivability problkems.
Old Aug 30, 2005 | 11:59 AM
CHVYPWR's Avatar
Thanks for the help guys!
Mark_ZZ3
May 24, 2018 01:02 PM
mrbird
Oct 20, 2015 03:43 AM
3.8TransAM
Sep 27, 2015 08:37 PM
Lmancha96
Sep 25, 2015 08:11 PM
Stryker412
Sep 20, 2015 06:59 PM
