setup?
Old Sep 2, 2005 | 12:24 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
setup?
Aluminum Bowtie block bored .020 over, Aluminum heads, Crane cams duration at .050 lift (intake/exhaust) is 204º/216º, while the value lift is .427/.454, Magnum roller rockers, 3.1L crankshaft and connecting rods, MSD coil, Accel cap and rotor, Accel 8.8mm wires, Denzo Iridium plugs, ported and polished upper and lower plenum, 17# injectors, and possible mustang throttle body. How much power do you think I can get with that setup? Is it worth the money? Would I be better off just turbo-ing my 2.8L V6? Dont want a V8 like the sixes.
Old Sep 2, 2005 | 03:35 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Stay away from the accell cap and rotor i had it on my car for a month and i was getting a miss and the whole thing was corroded. Go withthe autozone duralast one its 20 bucks and works great or get brog warner.
Old Sep 2, 2005 | 01:04 PM
KED85's Avatar
Go find a used low milage 3.4 long block and have at it.
Should run ya about $300-$600 range.
Have you found the price of your aluminum block yet? and do they still make it?
At one time was made, yeah, but, now why bother, when ya get a larger more powerful engine, working, for price of your engine rebuild kit
Old Sep 2, 2005 | 03:09 PM
FAST RS's Avatar
GMPARTSDIRECT sells the blick but i think it was 2000 plus
Old Sep 2, 2005 | 07:40 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i was thinkin it was around $3k but i could be wrong. not worth the money in my opinion especially with that cam and all. i'd get a 3.4 and turbo it or just turbo your 2.8 if its in good shape!
Old Sep 3, 2005 | 07:55 AM
86BLUEBIRD's Avatar
Car: 86 Firebird 2.8
Engine: 2.8l v-6
Transmission: auto
the aluminum block at full bore of .080 over does not compare to the stock 3.4 bore. the max designed stroke of the aluminum block is .11 less than the stock 3.4. the only benefit would be the weight. otherwise its a lot more money for less displacement.
Old Sep 3, 2005 | 10:15 AM
KED85's Avatar
I'd spend the $3,000 for that 2.8 aluminum block
by investing that $3,000 plus I believe $8,000 more and buy a GM reissued ZL-1 engine.
The Aluminum engine 427 Can-Am series race engine of the 70's.
If ya gonna buy an engine, do it right!
Find a used long block 3.4 and get back on road, quicker & using less money.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
