FUEL INJECTOR ... clean or replace?
Old Sep 6, 2005 | 12:52 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok i found where the tapping is comeing from with a stahtiscop., [lol] it is in the injector in the very front others are tapping but not as loud,. should i replace this injector or should i try and clean it.,,. how would i clean an electronic fuel injector? should i try the gas additive.,.,., it will cost 62 dollers at auto zone.,.,..,., But at least the knockin is not in the motor! so thank in advance for any and all feed back!
Old Sep 6, 2005 | 02:27 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
If the resistance of the injector is good then just clean them. But, cleaning won't stop the tapping. I had mine cleaned by rich at www.cruzinperformance.com and they still tap. Some more than others.
Any of that gas tank cleaner stuff isn't going to work as well as taking them out and having them cleaned.
Old Sep 6, 2005 | 09:21 PM
gottfuel's Avatar
thanks for reply bru333
well arent there some quality injerctoers that dont tapp that loud out there??
the quaot i got per piece for theses injectors was bout $60.,.,
every once and a while when i bump the key on i can hear that injecter in the front make like a grinding type pf primingi guess it would mean something was cloging it RIGHT???.
Old Sep 6, 2005 | 09:31 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
If it starts to sound HORRID, replace it.
The tapping is caused by the field coils getting weaker, allowing the control rod to move more than it should.
Eventually, the tapping will stop because the control rod has broken off, and fuel will be constantly flowing out of that injector.
Old Sep 6, 2005 | 10:00 PM
rowdywheels's Avatar
Car: 85 camaro
Engine: 2.8 mpfi
Transmission: 5 speed
never replace what you can clean
Old Sep 7, 2005 | 02:09 AM
gottfuel's Avatar
so....
so whats yall saying its broken orit can be cleaned,. what v6sucker said sounds like it makes perfect sence,. ill go with that
just straight replace it any one know where to get any cheaper injectors then $60 $65?? ,..,also what whould the car sound like if the injector compleatly goes
Old Sep 7, 2005 | 09:29 AM
V6sucker's Avatar
Engine: blown up
Re: so....
go to ebay and get a set of used 19 lbers off a V8...
install, reset ECU and enjoy getting rid of the lean spots.
The tapping would be gone. The rings would burn up in that cylinder in no time due to no lubrication on the cyl walls (fuel wash does that). You would get a studder as the fuel would pool, similar to hyrolock, and the spark plug not firing due to being fouled all the time. And the tell tail black smoke trail everywhere you went as you dumped raw fuel out the tail pipe.
clear enough picture?
Old Sep 7, 2005 | 09:40 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
19lbs on a stock 2.8 will be WAY to rich. I had 19lbs on a modified 3.4 and it was still to rich.
I know someone who has some used 15.4lb 3.1 injectors forsale.
Old Sep 7, 2005 | 11:24 AM
V6sucker's Avatar
Engine: blown up
they ran great on my 3.1 after I reset the ECU...
Old Sep 7, 2005 | 02:46 PM
gottfuel's Avatar
ok sounds good
if im correct to reset the ecu? i should or would dissconect the battery?`well im gonna do a 160 mi round trip i leave here in an hour.,., not sure what im gonna do yet guess ill try cleaning it of course., im looking to get the best gas milage i can., so maby if im able to clean it well enough ill save a lil fuel as well!!
Old Sep 7, 2005 | 03:02 PM
Dale's Avatar
Engine: 350 S-TPI
They will run, yes. But trust me, it is/would be running rich.
I had 19'bs on a modded 3.4, to much
Redraif had 19lbs on a modded 2.8, to much.
Anyway, you can try running a bottle of rubbing alchol thru the gas tank, it will clean them better then any "gas cleaner" off the shelf, and cheaper.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
