sputtering and jerking in 2.8 89 camaro
Old Sep 7, 2005 | 07:51 PM
jeremy_w's Avatar
changed the mass air flow sensor after checking the codes it was throwing out and it was also throwing a code for a digital EGR valve, but i was told i dont have a digital egr valve......
anyways, changed the MAF sensor saturday evening, ran fine, then sunday it got all jerky and sputtering when trying to go.
whenever i've got my foot on the gas its like i'm trying to tow a semi truck. thats what it feels like. and it jerks back and forth and such.
anyideas as to what it might be? fuel filter? sprakplugs? anything? i changed the plugs and wires last september
Old Sep 7, 2005 | 07:59 PM
wildlogger3371's Avatar
Car: 88 rs
Engine: 2.8
when was last time you put a fuel filter? is check engine light coming on? also catylitic converters can cause trouble like that
Old Sep 7, 2005 | 08:05 PM
86BLUEBIRD's Avatar
Car: 86 Firebird 2.8
Engine: 2.8l v-6
Transmission: auto
with the car idling, tap the mass air sensor where the connector plugs in. if the car chokes then you have a bad sensor. it happens. these are rebuilt parts and sometimes come bad.
Old Sep 7, 2005 | 08:46 PM
jeremy_w's Avatar
i've never changed the fuel filter. i got the car august 04 and changed the idle air control valve, blower motor, plugs wires, alternator, waterpump, oil pressure sending unit, and battery. since then its ran fine until this.
so i should tap the connection with the car idling? if its a bad sensor they'll replace it right?
and yes the check engine light is back on. i'm going to pull the codes this weekend. i dont get home until 830-9pm so i'll do it saturday morning
Old Sep 8, 2005 | 02:08 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
make sure you dont have any leaks in the intake ducting between the maf sensor and the throttle body. you might not have sealed up something when you installed the new maf senson, and if any air gets in or out after the sensor it throws off the readings.
post the codes here and i can look them up in my service manual if i have time(which i probably will).
give us your car information too(year engine etc), there are some differences between the years.
Cleotiz
Jan 6, 2018 08:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
