car all over the road
Old Sep 17, 2005 | 07:07 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
seems like when im driving i want to sway from side to side .,lik,. if i correct the stearing the it like i over corrected a lil to much.,it just kinda sways side to side like weight is shifting side to side.,should i just start with a front end kit then do alighenment? or perhaps some one here has had very similer probs and can tell me what needs to be done?!
dont wanna be getting pulled over c use it looks like im some kinda drunk driver.,.,
my 88 camaro had tight stearing im not sure if its in the stearing or the bushings in the front.,.,.,the only one that looks like it need a new bushing is what connects the pitman arm COULD THIS BE MY PROBLEM?
Old Sep 17, 2005 | 07:56 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
does it feel sloppy in the front end or the back? i know if i have my slicks on the back, it will sway a little because of the softer sidewalls... so, i'd double check air pressure to begin with then start lookin at "hard parts".
Old Sep 17, 2005 | 08:27 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
weaving, is caused by one of the following...
Lower ball joints (common)
Tie rod ends (outter is most common) Inners do go bad too though.
Wheel bearings (not so common-but it does happen)
Steering box needs remeshed (tighened up)
Ok how to check the above...
Lift the front end, with the weight off the tires.
Place hand @ 12 and 6 o'clock on the tire. Shake up and down on that axis. If it is loose, check wheel bearings and ball joint. To further narrow it down. Place hands at 3 and 8 o'clock. Shake, if loose look at wheel bearings.
Place hand @ 9 and 3 o'clock. Shake side to side. If loose have someone either shake the tire again while you look, or have someone look at the tie rod ends to see if they are moving.
To check steering box, either you or have someone GENTLY move the steering wheel side to side. You want to compare when the steering wheel moves, as to when the wheels move. If there is no disternable delay, it is fine.
To check bushings, you need to have the car off the ground with weight on the tires. Turn the steering wheel, if you see the "A" arms deflecting at all, they are bad.
Old Sep 17, 2005 | 08:31 PM
gottfuel's Avatar
Sweet could i see a pic or your 3.1 ride hopfully with the slicks .,that would make great wall paper.,., thanks for the advice bro!! also im running 205 65 15's pilot's in the front and 205 75 15's all seson's in the back., i know this setup sux but its all i got to work with right now., and the air psi is where it should be for the tires recomendation's
Old Sep 17, 2005 | 11:00 PM
Car: 91 Camaro
I don't think I've taken any pics of the car with the slicks on it (i'm not terribly fond of the wheels that they are on). but, you can see the different wheels on the car in a video posted on our sight...the "v6 idling with open headers" video. there's a link on the home page. you can't see the tires but you can tell that it has different wheels on the back.
Old Sep 18, 2005 | 08:15 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
adding to the list:
Center link (not a common problem)
Idler arm (mine was so worn out you could see it move 1/8" at the bearing when you shook the tire)
My car did exactly what you describe. I replaced ball joints, tie rod ends, idler arm, a-arm bushings and had alignment done. Now the steering is rock solid.
Old Sep 20, 2005 | 10:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, get an alignment/front-end-checkup QUICK ... if any of those parts are so worn out that they fail, you'll be in trouble.
The idler arm and center link are wear parts on our cars... meaning, they wear out anyway over the years, no matter how much you take care of the suspension. Idler arm is $70, center link is $110. If you do them yourself, you'll need to get an alignment done QUICK.
Old Sep 22, 2005 | 05:08 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
i got a white box 1 year warranty idler arm for 40$ canadain. TRW lifetime warranty was 100$. got a TRW lifetime centerlink on sale for 99.10 canadain.
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Exxon Limited
Aug 9, 2015 08:13 PM
