Eliminate Cold Start injector???
Old Sep 19, 2005 | 07:51 PM
LT1guy's Avatar
Car: 1987 Trans Am
I know TPI guys do it all the time (some aftermarket intakes don't even have a provision for it), but has anyone here? I know it would probably require some programming changes, at least in cold climates, but I doubt thats much of an issue. Redraif's cold start injector tube o-ring is leaking, and GM has discontinued the part...none of the local parts stores have it, either. I'd really like to just plug or TIG up the hole in the rail , plug the hole in the intake, and be done with it.
Old Sep 19, 2005 | 09:24 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You can use a freeze plug to put in the hole. Thats what they do on the 3.1 intakes. 3.1=2.8 intake plus freeze plug.
Then use a 3.1 rail.
I think you could leave as programed, would just have to crank a tad longer to start. But I dont know ecm info.
Old Sep 20, 2005 | 09:41 AM
mvftw's Avatar
I would be good if someone knows how to get the o-ring at least...
Old Sep 20, 2005 | 10:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dale, really? Gm does that from the factory?? Cool! Thanks for the info!
That O-ring is some kind of oddball specially-made-for-GM-only size... I couldn't find it anywhere, even at "real" parts stores with boxes of o-rings. I thought I posted the specs somewhere... but after a search of the forums, I guess I didn't.
Old Sep 20, 2005 | 10:31 AM
Dale's Avatar
Engine: 350 S-TPI
yes, really
That is the only difference I could find off the main base design.
Freezeplug where the CSI goes
extra pipe plug where some sensor up front goes.
Old Sep 20, 2005 | 04:43 PM
LT1guy's Avatar
Car: 1987 Trans Am
Sweet! I have never messed with any 3.1s (only Firebird and Fiero 2.8s, and 4th gen 3.4s) so I had no idea. Cool!
I was pretty surprised to see that GM discoed the o-ring though...the dealer was the only place I could ever find them!
Old Sep 20, 2005 | 04:56 PM
Dale's Avatar
Engine: 350 S-TPI
joe, if you find any differences on the intake itself, please let me know.
But when I had project85's engine here with the 2.8 intake, and my 3.1 pulled, that was the only obvious differences I could find.
Old Sep 20, 2005 | 05:05 PM
LT1guy's Avatar
Car: 1987 Trans Am
I doubt that there are, even the 3.4 intake looks interchangeable otherwise.
Old Sep 20, 2005 | 05:25 PM
LT1guy's Avatar
Car: 1987 Trans Am
Dale, is the 3.1 fuel rail identical otherwise? I just looked at the 3.4 one we have and the lines come in at the top, and are retained by a plate rather than screwing in.
Old Sep 20, 2005 | 07:37 PM
Dale's Avatar
Engine: 350 S-TPI
3.1 looks like a 2.8 w/o the threaded hole.
I may have a spare laying around here if you really need a pic.
Old Sep 21, 2005 | 05:08 PM
LT1guy's Avatar
Car: 1987 Trans Am
No need. thanks Dale!
Old Sep 22, 2005 | 10:35 PM
J Dahl's Avatar
Car: 1989 Firebird Formula
Engine: 5.0L TPI
Transmission: AT
Way off topic, but about cranking abit longer because of the no cold start injector. Is that good for the engine, cause it gives more time for oil to get shot around? Or does it stress?
Old Sep 22, 2005 | 11:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The cranking helps. My fuel pump doesn't prime till I get 7psi of oil
Which is sort of normal as its the factory back up if the reg fuel pump relay fails. But I have the main relay unhooked so only the back up circut will trip the fuel pump. But I like it that way.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
