whew! its just knocking from the torq converter
Old Sep 19, 2005 | 08:47 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
whew! its just knocking from the torq converter.,.,.,ever time i would drive thru a drive thru., like deltaco., i could hear a knocking noise., so finaly i got under the R/S and did a screw driver test to the bottom end of my 3.1 and could hear nothing., .,., So i moved towards the trans and identified the noise to be comeing from the torq converter., thank *** i thought it was coming from the the cam or lifters., so i guess some where on the converter there is a loose bolt.,., ill remove the plate covering the converter and check all the bolts,..,.,.,.,i suspect that is the problem!!
You guys dont think that the sound im hearing is the converter going bad do you??????????? i hane never had a converter go bad.,., what does one sound like if its bad or going bad? if any sound at all??
Old Sep 19, 2005 | 11:10 PM
XSVortex's Avatar
I have had the torque converter go out twice.... both times, it made no sound whatsoever.... just left a huge puddle of trans fluid on the ground. However, both of mine cracked the input shaft...
FormulasOnly
Sep 10, 2015 09:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
tgp1990
Sep 4, 2015 06:24 AM
