A lot of coolant leaking.
Old Sep 27, 2005 | 04:39 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I put in a gallon of Coolant and already it has leaked out. I checked the hoses at the front of the radiator, and where it connects to the block. It doesn't look like its coming from the water pump, but from the BACK of the engine. Has anyone come across a similiar problem.
Old Sep 27, 2005 | 05:41 PM
KED85's Avatar
Don't panic
Airflow causes the trail from front of car to back in 90% of time.
It's your radiator shot.
It's leaking under front hose, plastic tank.
Time for new one from wrecking yard.
Your Camaro is easy to find as it uses the V8 one, also.
V6 Firebird is unique until up to later 80's models.
Go get another radiator.
ONLY OTHER SPOT LEAKING IS
the timing chain cover.
IF not maintained rad system, it's corroding from within.
I know I had that happen too.
Actually had that spot under front rad hose break on me, too.
Now no leaks since replacing my rad.
SIMPLE TEST?
Put in the aluminum powder stop leak stuff & see how well it holds.
You may get lucky & be pleased.
I'll be giving ya a shout on the pan shipping real soon.
Resting from cleaning houe for showing & selling.
Old Sep 28, 2005 | 01:05 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
is it leakinkin as soon as you put the fluied in?? and if i here ya correctly and your saying its leaking from the rear of the motor.,then im think somthing along the lines of your intake manafold leaking,.,. but then againg try raising the front end or lookin back there to try and identyfyi where it comeing from,..,im sure soome one here knows more bout it,.,.good luck to you,. i hope its nothing serious
ill be watchin to see where it was coming from.,., so keep us updated
Old Sep 28, 2005 | 07:37 AM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
It only happens when its turned off. I'm gonna raise the block up today and see if I can tell exactly where its coming from. Thanks again for the pan KED85, and i'll try that aluminum powder. Yeah I'll keep you guys updated. I hope its nothing serious too
Old Sep 28, 2005 | 08:28 AM
KED85's Avatar
Try the powder stuff when the rad is low of fluids.
But yeah pour it in warm rad tank, not cold.
When it again leaks, remove the top rad hose.
The crack is below, there.
I'll be giving shout later on, happy to pass stuff along.
Old Sep 29, 2005 | 01:36 AM
gottfuel's Avatar
Wait wha ?????? A crack? i surly musta missed somthin! ok when you say upper rad hose im thinkin to the block and that would be where the thremo is! ..........hopfully you mean crack in the radator!!
Old Sep 29, 2005 | 09:22 AM
KED85's Avatar
Yes Plastic tank, top rad hose, underneath that area.
During this past summer, mine went.
I had coolant leak and couldn't find it.
One stop light, my rad crack let go like Niagara Falls.
I saw the HOLE!
Then while chatting about it, atleast 3-5 others said same story.
Apparently it's "common".
I got a Modine rad from yard for $45 and been fine since.
IF I HAD not seen it, I wouldn't have believed it.
NO REPAIR REPLACE THE WHOLE RAD!
Hope this is good clue for ya.
PS That lower rad hose?
Make sure it is SECURELY ON THE RADIATOR!
Mine came off while driving and that's how I learned to do the 2.8->3.4 Long Block Swap Boogie.
I still have my 2.8 number one piston with the silver dollar hole in top from engine letting go while cresting the Sepulveda Pass of the 405 in Los Angeles.
Hose came off & I killed that engine. Oh well.
Old Sep 29, 2005 | 05:26 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I was loseing coolant for the longest time then i was putting a gallon a day with no signs of a leak i finaly found the side tank of the radiator was leakeing and had a crack in it.
Old Oct 1, 2005 | 08:42 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
I'll second that. Couldn't find it for the LIFE of me, went a week delivering pizzas in it, and stopping at the chevron with free water to top it off between every other delivery. I thought for sure I had a crack somehow at the back of the engine.
Then that saturday I decided to pull the upper radiator hose, and BINGO, it came off in my hand. New radiator fixed it right up. Found a nice all metal version in the wrecking yard thats still working strong.
Old Oct 1, 2005 | 08:53 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
well, i found the leak after putting it up on the ramps. turns out its the weep hole in the water pump. so now i get to do the water pump boogie? gonna set some time aside on tuesday to do it. shouldn't take more than a couple of hours right? and i'll make sure to RTV the threads on the bolts reaallll nice.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
89 formula TPI
Oct 6, 2015 08:40 PM
FormulasOnly
Sep 10, 2015 09:07 PM
hdis2002
Sep 8, 2015 02:52 PM
