Junk??
Old Sep 27, 2005 | 06:25 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Junk??
I wanna know everyones opinion on this stuff..... IMO it is a pile a junk that is of no use to me.... All replies are welcome...
Old Sep 27, 2005 | 07:17 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i'd say its worth trying to sell
Old Sep 28, 2005 | 05:03 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
How many miles on that stuff?
Old Sep 28, 2005 | 07:04 PM
160,xxx miles.... Had them slightly ported/gasket matched. Got all the carbon crap out of them.
Old Sep 29, 2005 | 04:17 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if your throwing it away i'll take those sockets
Old Sep 29, 2005 | 11:11 AM
LOL Sorry sockets are needed and arent being thrown away anytime soon. Not getting rid of intake and such just yet. I just wanted to know what everyone thinks of it.
Old Oct 4, 2005 | 05:50 PM
KED85's Avatar
One mans junk is another mans treasure
I'd hold onto it.
Even tho I'm moving, I'd hold onto it.
Old Oct 4, 2005 | 06:33 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
i would take that fuel rail (hell, i'd take all of it, im a pack rat), i think my **** is spoiled(as in ultra-minor but still present fuel leak and other wonderful things).
rest of it i would just use for ****s and giggles probably, see what i could do as far as porting or creating a UIM, etc.
junk? probably. useful? probably.
Old Oct 4, 2005 | 11:33 PM
v6#21's Avatar
Something in my junk pile if anyone wants to make me an offer.
Old Oct 5, 2005 | 11:32 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i got the upper half of one of them... and the fuel rail. i'll probably hold on to the injectors for now, though.
Old Oct 5, 2005 | 11:56 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
If I was building an iron head engine, I'd be all over that like a fat kid on Smartie.
Can you do me a favour? Can you measure the TB size for me? TIA.
Old Oct 6, 2005 | 12:01 AM
rx7whoreboy's Avatar
what the heck is that contraption?
same with the first pics posted?
Old Oct 6, 2005 | 12:24 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
those are the intake and fuel rail for 60* V6 engines. hey V6#21 what is the one you are showing from? is that a custom made one or a stock one? if it is stock will it fit my 2.8? and if so where can i get one? i like the idea of being able to get to the Fuel rail without having to take off the upper part of the intake
Old Oct 6, 2005 | 01:06 AM
from what car though. it doesn't look like any stock f-body piece I have seen
Old Oct 6, 2005 | 01:52 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The one that v6#21 is showing is a stock 3.4L intake. Nothing special and it won't clear the distributor on 2.8/3.1L motors.
Old Oct 6, 2005 | 07:25 AM
KED85's Avatar
The 93-95 SFI set is a shame due to it will not work under the hood of the 3rd Gen
ANYTHING CAN BE DONE
But in end, it won't work.
Does look great.
I have a spare set also available.
I'll be unearthing it shortly.
This SFI set up is like the Fiero intake.
Because of neck of air entry and that angle, it canno work on the 3rd Gen engine bay.
The air entry measurement is identical in size to what is used from 1985-1992.
This 3.4 intake is a one piece, a slight bit shorter in height to "fit under" the deep hood slope of the 4th Gen f body.
And yes, no chance to slip in distributor using this set up.
Because the intake was designed to be a "dsitributorless" set up (as in the DIS system using balancer sensor among other specific stuff).
This is pic of the first set I sold.
Old Oct 6, 2005 | 10:01 AM
xplane's Avatar
Engine: 2.8 MFI
well i have been looking into geting a crate 3.4 from gm and i was thinking that i should be able to swap the oil pan to make it fit but i dont like the idea of using intake parts ment for a smaller engine like the 2.8l i have now. shurely you would loose some power right?
Old Oct 6, 2005 | 10:23 AM
KED85's Avatar
IN THE WHOLE SCHEME OF THINGS
YOU WILL NOT LOOSE ANY POWER.
The increase in performance is breath-taking.
The MPFI set up works perfect on top of the 3.4
I know I've done it twice, over 125 people have swapped up & only one unhappy with results.
That's a 3.4 under there.
What's best is that the original stuff (my 1985 stuff) compliments the 3.4 power increase so well.
Honest not a problem at all.
You will be most happy with end results.
Old Oct 6, 2005 | 04:35 PM
The_Raven's Avatar
The DIS uses a crank mounted sensor for triggering, the balancer mounted sensor is for the SFI ECM.
Anybody have any pics of that intake on an engine in the area where the dizzy goes, and even better would be a dizzy sitting that area to show the interferance. I'm sure with some slight modifications it would/could work with a dizzy.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
