cruise controll
Old Sep 30, 2005 | 12:45 PM
mmadreman's Avatar
Car: 88 camaro
Engine: 2.8 mpfi v6
Transmission: 5 speed
cruise controll
my cruise controll was working fine,then the other day i was cruising at 75mph and it started surging like it was bleeding off a lil vacuum or something,,,, it would drop to about 72, then back to 75 and so on......... oh, 88 2.8mpfi 5 speed... what's up with this thing???
Old Oct 1, 2005 | 02:11 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
Ya know what! im intrested in this topic., I dont have cruz controll but i realy am intrested.,i wonder how they even did that with a 5 speed manual?? im used to the auto's with the C/C,.
I would think with c/c that at some point the trans would need to sift up and down as it was going up or down hills,,.this is something i have not got into yet.,but am very intrested,.
Ill give ya my 2 cents anyway [lol] asuming the c/c is electronic.,perhaps some where it is shorting out
Old Oct 1, 2005 | 08:33 AM
mmadreman's Avatar
Car: 88 camaro
Engine: 2.8 mpfi v6
re
well, the switch is ok, i adjusted the switch on the clutch , and gave a 1/4 turn on the bleed valve on the brake,,, it still wanted to work like a check valve,(releasing intermittened bursts of psi)so, i just turned it back off..... about a month ago i got a speed sensor code, so i checked it out, cleared the codes and it never came back, but mabey it has something to do with it.... any more sugestions from anybody would be appreciated....
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
