fuel pressure regulater.
Old Oct 2, 2005 | 02:21 PM
mmadreman's Avatar
Car: 88 camaro
Engine: 2.8 mpfi v6
Transmission: 5 speed
i read somewhere that a leak past the o-ring on the regulator will give an exxcessive rich condition.. he was talking about a 3.1, but does that go for any regulator??
Old Oct 3, 2005 | 03:56 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
good question! i would like to know where exactly my fuel pressure regulator is at??
i also can smell a rich smell of fuel, usualy when im at idel for a few,, or just coming off the freeway.,ide like to check my fuel reg, if i could find it,..,lol.,.,
Also *mmadreman* somthin you might want to look in to is , i read on here some where a while back that at one time the 91's has a recall for the fuel tank.,i believe there was an issue with the filler neck .,something about, a part thats soderd it develops a small hole over time causing rich smell's and leakage., also im not sure but, there is a way to check to see if your car had the recalled work done or not,.,.maby some one else here will be able to shine a lil more light on this subject........
Old Oct 3, 2005 | 06:32 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the fpr is located on teh fuel block itself, inbetween the upper & lower manifolds. The injectors connect directly to it. THe regualtor is the rcircular part in the front w/a vacuum line connected to it.
I'm gonna have to pass on the o-ring question
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
