High rpm power
Old Oct 12, 2005 | 03:28 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
High rpm power
I want my car to pull on the top end. Need ideas on cams and exhaust setups to go with. Also what else would give me better power up towards 6000rpm's?? Ive hit 7200 but I ended up breaking a rod. Had it packed away in a box just found it today so I should be able to get a pick of it soon. Also is it possible to have the rods milled down for less weight? Thanks
Old Oct 12, 2005 | 03:35 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
New intake
Headers
210º minimum @ .050" with .450"+ lift.
Old Oct 12, 2005 | 09:29 PM
Intake is almost done so I'm hoping it will give me more power and better flow. You wanna make me some headers Doward? Id rather have custom ones by you than pacesetter. im either gonna have a muffler or a cat not both so wich would be better? What about lifters and rockers? Are they worth it? Same with ASP crank pully.
Old Oct 12, 2005 | 10:03 PM
Would this cam be good?? It says use with 10.5-12.0 comnpression ratio tho. http://store.summitracing.com/defaul...=egnsearch.asp
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
