The Vixen's heart is that of an F Body.
Old Oct 13, 2005 | 10:39 AM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
Well gang, I picked up the car last Thursday, with the new 3.4 crate engine and TKO 600 5 speed. I am hold the revs to 3000, and all I can say is wow, and wow again. I can't wait for the engine to be broken in, so I can see what the car can do. Remember it only weighs in at 1700 lbs.
Now my question, anyone with a 3.4 crate engine put in roller tipped rockers, if so what brand and the part number please.
As always thank you for the help.
Paul
Old Oct 13, 2005 | 10:54 AM
v6#21's Avatar
Paul, there are two levels of cost and performance values to go with in roller rockers. With 1.6 rockers, Both styles you WILL need to use a set of Fiero aluminum valve covers so you have clearance. They will hit the stock covers.
You can get away with magnum rollertip 1.52 rockers on factory cam, springs, and vavle covers (I actually have these on my 2.8 currently) , Or change the appropriate parts and go magnum 1.6.
The better choice for higher revving power (especially with your low power to weight ratio) would be the Crane full roller rockers ("Gold Rockers")
I'll find you part #'s through summit and post those
Dean
Old Oct 13, 2005 | 11:03 AM
v6#21's Avatar
Comp Cams Magnum rollertip 1.52 rockers
part # CCA-1413-12 (Summit Racing)
I do not see the Crane Golds listed through Summit any more. Here is an "expensive" link through the FieroStore showing the Gold kit with the needed rocker studs
http://www.secureleadercom.com/fssto...ics/52803a.jpg
Edit: Summit does have them
Gold 1.5's part # CRN-25750-12
Gold 1.6's part # CRN-25759-12
Old Oct 13, 2005 | 11:38 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Re: The Vixen's heart is that of an F Body.
Paul
How does your car only weight 1700lbs?
Old Oct 13, 2005 | 12:06 PM
TVRPAUL's Avatar
What about Comp Cams roller rockers the 1.6???? ones.
I think they are 1414-2
Paul
Old Oct 13, 2005 | 12:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: Re: The Vixen's heart is that of an F Body.
tvr vixen? http://members.tripod.com/sperera/tvr.html
Old Oct 13, 2005 | 01:20 PM
TVRPAUL's Avatar
It weighs 1700 lbs because it is not an F Body. I am at work so I cant attach a picture, will do it tonight. Carl knows what it is
Paul
Old Oct 13, 2005 | 01:28 PM
TVRPAUL's Avatar
That is what it looks like, except its white with strips
Paul
Old Oct 14, 2005 | 02:25 AM
v6#21's Avatar
Paul
Thad be them. Caution though, you may need taller Fiero valve covers for them in the 1.6 ratio for clearance. They come up taller and *may* tick against the stock valvecovers.
http://www.powerandperformancenews.c...ry_Code=mgRCKR
Summit has them offered at $135.69
Falcon50
Aug 22, 2020 03:26 PM
no green
Jan 9, 2016 09:22 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
