tranny
Old Oct 13, 2005 | 04:10 PM
mtd861's Avatar
tranny
Hi just found this site looks cool with alot of good info! Was wondering if the tranny fluid and filter have never been changed at 92,000 should it be done right away. I've heard that disturbing the fluid and filter may damage the transmission. 89 firebird2.8 Thanks
Old Oct 13, 2005 | 04:11 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
change it, always good to do
Old Oct 13, 2005 | 04:52 PM
v6#21's Avatar
Re: tranny
What can happen is if the trans fluidhas been in theree so long *AND* the tranny is showing signs of slippage, you do not want to change the fluid or it will immediately kill the trans useage.
HOW and Why?
When a high milage trans starts to slip, the old fluid retains some of the friction particles in the old fluid that will help aid the internal clutch packs from slipping. When you drain the old fluid and install new fluid, the clutches will really slip and the tranny is dead.
If you are not showing any signs of slippage, then service it immediately. Otherwise, leave it and start saving your money for a new trans real soon.
Old Oct 13, 2005 | 04:57 PM
Engine: 364ci LS2
Axle/Gears: 3.46
wow didnt know that... ill keep that in mind.
Old Oct 31, 2005 | 12:19 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
wha?
well what you said makes sence but.... ive noticed from expiriance that if i have a tranny slippin if i change the filter and fluied the sliping tep goes away.,for a while.,.,this was an ol trick i saw my father do when selling a ride with bad trans.,.,it has worked for us befor., but once it starts slippin with the new fluied its GONE
Old Oct 31, 2005 | 04:08 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
does any of this apply to manual trannys?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
