Starter problem update
Old Nov 2, 2005 | 02:34 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Well...this morning I used a screwdriver to jumper the starter between the battery lead on the starter and the "S" terminal. I heard the starter kick in and the flywheel was engaged when the starter turned over. The car still did'nt crank but maybe the starter aint bad. I noticed when I turned the key to the RUN position also, that the SECURITY light did'nt light up at all. The fuel pump did prime so if I'm not mistaken, does'nt the VATS system also control the fuel pump? It would seem if the VATS was bad, the pump would'nt prime at all. Correct me if I'm wrong. The only thing I can think of is the key cylinder switch, ignition switch box or the P/N switch. I'm hoping it's not the key cylinder switch.
I'd hate to rip of the steering wheel to get to that sucker plus take it off. The GM place said they had a way to test the key lock switch to see if it was bad or not. Anyone ever hear of that?
Ken
Old Nov 2, 2005 | 04:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
vats deals w/starter, passkey deals w/fuel/injectors
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
