what do you think of this custom intake manifold
Old Nov 14, 2005 | 05:17 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
a guy i work with has done lots of custom work on DSMs and come custom work on an 11 second corvette, so i think he knows what hes doing. were currently working on a custom intake manifold for my camaro. were going to take the manifold and the lower plenum, P&P it quite a bit, and weld on a 3" Y-shaped pipe to the throttle body. itll look a lot like the 3.4 intake plenum. do any of you with custom work think that 3" pipes to the plenum will be too much? were going to use the stock throttle body mount for now, but ported out quite a bit and later switch over to a bigger throttle body. is it a good idea?
Old Nov 14, 2005 | 07:28 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Re: what do you think of this custom intake manifold
Air flow dynamics and CFM by RPM will tell you what size you need.
However, just off the top of my head 3" should be ok. You figure that ios roughly the size of 3 intake ports' volume.
I think it would start to be a restriction around 7K or so.
Old Nov 14, 2005 | 07:30 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
speaking of custom intake manifolds anybody kno what is up with trueleo's intake and alans custom intake?
deracer
Apr 11, 2016 12:04 AM
The Tank
Aug 30, 2015 06:16 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
