Where is the fuel pump relay?
Old Nov 17, 2005 | 08:54 AM
dxacer01's Avatar
Car: 89, 87, and 84 Firebirds
Engine: 2.8. 2.8, 350
Where is the fuel pump relay on a 1989 2.8 Firebird, haynes doesn't have anything about the relay that i can find
thanks
steve
Old Nov 17, 2005 | 10:17 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I thought it was on the passanger fender well by t he head lights...
Old Nov 17, 2005 | 11:20 AM
dxacer01's Avatar
anyone else to confirm this? Someone on the electronics board said it was near the brake booster on the firewall but i thought that one was the fan control.
Old Nov 17, 2005 | 12:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes, break booster, drivers side firewall. Picture was posted by someone just ealier this week(or late last week). I posted in that thread if you want to search my user name, v6 section.
I belive fuel pump is ran off a gray wire.
Old Nov 17, 2005 | 02:32 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Yup
Old Nov 17, 2005 | 02:35 PM
dxacer01's Avatar
cool thanks, i switched the a/c relay with the fuel and am still haveing the same problem so I am kinda lost on what to try next I did find a hose that i have no clue where it is soppos to go but is sucking in air (check out thread "completely confused)
Old Nov 17, 2005 | 03:06 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
do you or did the car from a state or city where they do smog test???
One trick to pass is to make a hidden vacuum leak.
Though its not good to leak vacuum all the time.
[PO might have left it open so you would pass]
Is the car still starting?
Mine has the bad relay system. It was fried, melted along with the AC relay. Like the connectors over heated. N E ways I spent some time trying to fix it right then said hell with it. And so far I have been happy with things. I'm glad my car doesn't start till I get 7psi of oil pressure. I might have to crank it 1-2 times to start but its probably why the car has run so well with so many miles. Cause it was like that when I bought it 6-7 years ago.
a first little anoyance turned into a blessing once thought out.
The car shouldn't start till you get oil psi first, then prime the fuel pump and then start.
I think it should be like that on all cars. Start up wear causes the most damage and a dry start up causes even more. Sure someone already figured that out but cars lasting to long was counter productive to sales.
Old Nov 17, 2005 | 03:11 PM
dxacer01's Avatar
car starts just fine, its running thats the problem it runs very roughly, surges, stuff like that..car has always been in florida so it has never had to pass any test of any kind
Old Nov 17, 2005 | 08:22 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
could that be a bad throttle position sensor?
Old Nov 18, 2005 | 05:18 AM
V6sucker's Avatar
Engine: blown up
surging is mostly caused by vacuum leaks and or bad intake gaskets.
Old Nov 19, 2005 | 12:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
ah ic ic....I guess i'd better do a check for those things on my car!
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
