buahh, almost figured it out
Old Nov 23, 2005 | 05:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Took rbob's advice a but futher, and disconnected everything vac assisted off the engine, and put the meter on it.
So:
hvac
break booster
purge canister
No vac leak, engine revs fine, sweet
Hook purge canister back up, runs fine, sweet
I had pulled hvac off before, no effect, sweet
this leaves me too, something in my break system is causing the excessive vac leak causing it to run like crap. After dinner its new hose, hose clamps, and check valve first.
What are the odds that something like that goes out the second I fill it with gas
So rbob, how much do I owe you?
Old Nov 24, 2005 | 08:38 PM
KissThis's Avatar
Car: 1984 Firebird V6
Dale,
I noticed you have a 1991 Camaro RS....
If you go to the Body and Interior board there is a Big notice posted up there about Gas Tank recalls for your year of car.
Just thought I would FYI ya
(Edit)
https://www.thirdgen.org/techbb2/sho...hreadid=332472
Did ya one better
Old Nov 25, 2005 | 05:19 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
hey how's the progress coming? Did you get it running good?
Old Nov 25, 2005 | 08:26 PM
Dale's Avatar
Engine: 350 S-TPI
The vac leak was the check valve and hose going to the booster.
We poured some of the gas out, that I sucked out of the tank, somethings not right with it. So I am going to drive it tell it dies on gas. Then fill it up and install new plugs, and run a de-carbon kit on it.
Running WAY better then when I first had this problem, but still not fully right. Praying its combo on bad gas, vac leak, and now new/dirty plugs.
I installed my new double heim joint lca's today. Buahh *chants* no more bushings, no more bushings
Old Nov 26, 2005 | 03:26 AM
1989karr's Avatar
Engine: 3.4 / 5.0
awesome awesome! keep us posted!
Old Nov 26, 2005 | 02:25 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
good work, sometimes its the weirdest things that causes problems
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
