3.4L RWD short block
Old Nov 18, 2005 | 01:56 AM
BigNorm's Avatar
Does anyone have a good source to order a short block from? I just looked over my local bone yard today and there was plenty of older 2.8L RWDs but no 3.4s. I may be better off just going with a short block for now and building it up.
Old Nov 21, 2005 | 11:39 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
www.car-part.com
Old Nov 21, 2005 | 02:10 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
It shouldn't cost more than 800 bucks to have a 2.8 rebuilt and bored to a 3.1, plus you'd have a new motor....
Old Nov 21, 2005 | 09:33 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
2.8s and 3.1s have the same bore. the difference is in the stroke length.
Old Nov 22, 2005 | 01:08 AM
Blue1989RS's Avatar
Car: 1989 RS
I hope I didn't loose any face by saying that..... but he could still bore it and get close with out having to getting another crank. I think it would be about 3.05L?
Old Nov 22, 2005 | 02:54 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
the way i see it is a 3.1 over a 2.8 is a 10% gain, and to to a 3.4 is another 10% (from 2.8). if you say no to the 10%, thats half of the gain you arent going to get. you could buy a 3.4 shortblock for an extra $100, rebuild that and get double the gain(bore & crank are only differences). and if you bore the 3.4 block, theres even more gain.
Old Nov 22, 2005 | 09:26 PM
BigNorm's Avatar
Naft is right on track with what I'm thinking. That and the earlier 2.8s like have were notorious leakers. I want to start with an engine GM got most the bugs out of rather than dealing with the older mill's problems. As of right now I'm thinking of going with the 3.4 block and heads, 2.8L carb intake and maybe a Weber carb or a TBI intake off of an S10 with a 2.8. Thanx for your input. You guys have been great.
How much of an overbore will these blocks accept?
Old Nov 23, 2005 | 11:04 PM
Naft's Avatar
if you get it sonic tested the upper limit is .070 i think, but that would be with a perfect block, and you wouldnt have any rebuilds left to it.
id say .030 is a safe bore, go .040 if you want, but anything higher than that and you would probably have to get custom pistons, and would be pushing it without getting the block tested. although people pretty much give away broken 660 engines, so maybe worrying about keeping the same block is pointless.
Old Nov 25, 2005 | 03:14 PM
Blue1989RS's Avatar
Car: 1989 RS
I did .060 on mine and repeatedly take it to 6500 without a worry. The pistons were on the shelf at the rebuild shop. No custom orders. Plus, if I have to get a new block at 150k, who cares. It will take me another 10 years to put that many miles on the car! But it would probably be more reliable to only go as far as .040 like he said. The 3.4 is a bore .120" larger than the 3.1 right?
Old Nov 25, 2005 | 04:44 PM
Naft's Avatar
its 3mm, so whatever that converts to . . . . .3/2.54 = yah .120
the aluminum 2.8 can be overbored 2mm, but thats still only .080 overall there ends up being around .2l that you can never get without starting from a 3.4 block
Old Nov 27, 2005 | 12:19 AM
BigNorm's Avatar
You guys are awsome. Does anyone on the west coast know where I can get a 3.4 motor complete? I'm back and forth between using and not using the Fuel injection. I think I should do it!
Old Nov 27, 2005 | 12:24 AM
Naft's Avatar
heh, im in the market for a 3.4 too, so if i find 2 ill be sure to let you know.
Old Nov 27, 2005 | 12:56 AM
BigNorm's Avatar
Mine needs to be RWD as well.
wigmobile
Feb 26, 2025 02:56 PM
Loudnproud86
Jul 14, 2016 12:59 AM
RyanJB
Sep 14, 2015 03:39 PM
Kenwood
Sep 11, 2015 12:50 PM
64goatman
Sep 9, 2015 01:09 PM
