Gas Tank Recall...Read if you have a 1991 Camaro RS.....
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Gas Tank Recall
1991-92 Camaro Gas related Recall Information
http://www.autorecalls.org/1991/431.shtml
http://www.internetautoguide.com/aut...let/camaro/rs/
In general, the reason so many people don’t respond to recalls is because they simply don’t understand the recall process. The NHTSA , National Highway and Traffic Safety Administration, is responsible for investigating consumer complaints regarding specific vehicles and problems associated with them. After several consumers have reported the same or similar problem to the NHTSA for the same model vehicle an investigation is launched.
Regardless of whether or not you believe you are driving a safe car you need to check out the websites stated above every few months just to make sure your vehicle has not ended up on the list. If it has, don’t fall into the two thirds of individuals who never respond to the recall. Instead, head to the nearest dealership or authorized mechanic who can make the free repairs to your vehicle. Why so many people don’t have time for free repairs is beyond me, but knowing your vehicle has a problem that could be potentially fatal for you and your family and that a free repair is available should be enough to motivate you to have the repair taken care of.
The point of the NHTSA investigation is to determine whether the consumer caused the problem or malfunction in some way or if the manufacturer of the vehicle is at fault. If the manufacturer is determined to be at fault then the owners of affected models will receive information in the mail regarding the recall of the vehicle with information included on how they can have the problem corrected free of charge. However, the NHTSA is not always the one who issues a recall.
Here are some steps that you can take if you smell gas or see it leaking from the rear of your Camaro.
Recall
1991 Chevrolet Camaro RS NHTSA Recall ID Number: 94V077000
Recall Date: APR 25, 1994
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Potential Units Affected: 232988
Summary: THE FUEL FILLER NECK SOLDER JOINT CAN DEVELOP CRACKS OR PIN HOLE LEAKS, WHICH DOES NOT COMPLY WITH FMVSS NO. 301, "FUEL SYSTEM INTEGRITY." THE CRACKS AND HOLES CAN ALLOW FUEL VAPOR AND FUEL LEAKAGE.
Consequence: CONSEQUENCE OF NON-COMPLIANCE: GASOLINE VAPORS AND FUEL LEAKS CAN RESULT IN A FIRE IF EXPOSED TO A SOURCE OF IGNITION.
Remedy: DEALERS WILL INSPECT THE FUEL TANK ASSEMBLY AND REPLACE THOSE WHICH EXHIBIT THE CRACKS OR PIN HOLE LEAKS.
Notes: GENERAL MOTORS CORP., 92C36
1.)Acknowledge that your fuel tank or Fuel Neck is leaking and needs replacing, if you smell gasoline.
2.) Understand that there is a Safety Recall and it is still open.
3.)It does not matter if you are the 10th owner of your 90-92 Camaro, a safety recall doesnt go away or the Camaros name isn't Chevrolet Camaro.
4.) It's free! you dont pay squat.
5.)Do not let dealers push you around or let them give you the run around.
6.) Dont question your safety! head to your local dealership and have them fix it!
ALSO UNDERSTAND THEY MOST LIKELY DONT HAVE THE GAS TANK IN STOCK SO THEY WILL HAVE TO ORDER IT, THIS SHOULD TAKE NO MORE THAN 1 WEEK
MODERATORS OR ADMINS PLEASE POST THIS UP (STICKY)
Recall
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Originally posted by 88txiroc
Stuck to the top.
Some good info to know. Seems that it only affects the 1991 Camaro RS, so I changed the title a little....
Stuck to the top.
I want people to be aware, so they dont get the run around. Member
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
hmm so there's something similar for my 88
http://www.internetautoguide.com/aut...ase/index.html
if this is the case I need to drop by the dealership cuz I smell gas...wait the dealership will fix this right? lol
Axle/Gears: 4.11 posi Ford 9"
On both sites, if you click on "HOME", you get back to a point where you can check any year and model of car. My 91 Firebird had the same recall notice.
Limitations on remedy of defects...
Hi all, found this on the official NHTSA website....
Are There Any Limitations on My Right to Have My Vehicle Remedied at No Charge?
Yes. There is a limitation based on the age of the vehicle. In order to be eligible for free remedy, the vehicle cannot be more than 10 years old on the date the defect or non-compliance is determined. Under the law, the age of the vehicle is calculated from the date of sale to the first purchaser. For example, if a defect is found in 2003 and a recall ordered, manufacturers are required to make the correction available at no charge only to cars purchased new in 1994 through 2003. However, consumers should realize that even though manufacturers are not obligated to remedy safety defects in older cars, a safety problem may still exist. If you receive notification of a defect on a vehicle older than 10 years, take the responsibility to have your car repaired at your own expense. Eliminate any unnecessary safety risks.
I myself own a 91 rs and am the 5th owner, I'm not sure when this recall went into effect.. if it was after 94 then possbly this gas tank filler neck fix may still be a no charge dealer responsibility.. I hope.
DR
DR
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
my car was sold in 1991 and it is now almost DECEMBER 2005 and my car is scheduled to get fix next wensday. So far I have payed nothing.
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Re: Limitations on remedy of defects...
YES IN 1994 IT IS A SAFTEY RECALL UNDERLAW THEY CANNOT CHARGE YOU TO FIX THIS PROBLEM IT IS THE MANUFACTURES RESPONSIBILITY TO HAVE THE SAFETY RECALL FIXED, AND IF YOU GO TO A DEALERSHIP AND GIVE THEM YOUR VIN NUMBER AND IF IT THE RECALL IS STILL OPEN AND THEY ASK YOU TO BRING IN YOUR CAR AT A CERTAIN DATE AND TIME WITHOUT BEING QUOTED OF ANY CHARGE THAN IT SHOULD BE FREE, AND IF THEY SAY YOU WILL HAVE TO PAY AFTER THEY FIX THE RECALL , YOU ARE NOT OBLIGATED TO BECAUSE THEY NEVER QUOTED YOU.
DR
DR
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
*SPECIAL NOTE*
I know most of us have a 80 series flowmaster muffler installed, if the people who install your new flowmaster decide to also install new pipes leading to your catalytic converter
and weld it instead of bolting it on, the dealership people will see this and make you go to a shop to go have it done right or cut the pipe THEY WILL NOT CUT IT!!!! so make sure you do the same, most muffler shops will cut it for free or charge you a very low fee because it only takes a couple of mins to do. ( when the pipe is cut your camaro will sound like some 50s hot rod ahaha)
ALSO**
After the gas tank is installed be sure NOT to ride around with the pipe cut around like that, it is very loud and YOU WILL GET PULLED OVER AND BE TICKETED.
ALSO**
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i had mine done last year but never smelled anything untill after i had it checked
but before it they tryed giving me the run around telling me the soap they had to use to chaeck it had dried out and all that kind of stuff
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Just got my car back from the dealership took them 1 day to fix it.
THE ONLY PROBLEMS THAT I ENCOUNTERED WERE
SCHEDULE (DEALERSHIPS)
CUTTING THE EXHAUST PIPE (WHICH I HAD TO DO)
AND HAVE TO PAY TO WELD IT BACK UP
BUT ITS ALL GOOD
GOOD STUFF!
THE SERVICE DIRECTOR WAS COOL
HE DID EVERYTHING HE WAS SUPPOSE TO
MY CAMARO NOW HAS A NEW TANK!
HERE IS THE WORK ORDER TO PROVE THIS COSTS NOTHING! AND THE RECALL IS STILL VALID! (NOW ALL OF YOU ARE GOING TO RACE TO THE TORRANCE CHEVROLET DEALER!!! HAHAH)
BUT ITS ALL GOODGOOD STUFF!
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I had my tank replaced long ago (on recall). They had found pinholes in the neck-tank joint and replaced it. Took a day.
I never thought much of it until I dropped my tank this summer to replace the fuel pump.
They eveidently lost or damaged the rubber vibration isolator strips on top of the tank and replaced them with 15# felt paper (used for roofing applications)!
Even certified mechanics can pull hillbilly bullschnizzle in a pinch.
This dealer, by the by, was Rockenbach Chevrolet Grayslake, IL
S-D
S-D
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
So........
I have a 1990 RS and I smell gas around my car.... especially when the tank is full.
on the NHTSA website, it does not list the soldering problem on the 1990 models.
So does this mean i'm screwed?
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
BUT ITS ALL GOOD
GOOD STUFF!
hah i used to work there, thats my buddy richard who wrote your car up. but i will have to disagree with you that the service director was "cool".
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Go to your nearest Chevy dealer find out if the RECALL is still open! I did and look at me!
Originally posted by MikeDirntRulez
So........
So........
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I should have checked this when I changed out the fuel pump. Because now I got some minor issues, seems like gas mileage may be down a bit, plus a tiny bit more fuel smell.
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
so are you from the torrance area?
Ad if you have a91-92 camaro rs it is free!!! FREE!! AS YOU CAN SEE! by law!
Car: 1991 GTA
Axle/Gears: Its posi.... :)
On a side note about all this for a good laugh go to that site, or click this link http://www.autorecalls.org/2000/FORD.shtml and look at all the ford recalls. Will make you glad you didnt buy a ford
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
i have a 91 rs, im getting ready to pull the tank out and sump it...you think if i get it checked out and it does have pin holes or whatever, they will just give me a new tank, without installing it? Doubt it huh...
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Car: 91 Z28
Axle/Gears: Stock
Well, this page says:
NHTSA Campaign Number: 94V077000
Vehicle/Equipment Make: CHEVROLET
Vehicle/Equipment Model: CAMARO
Model Year: 1991
(http://www.autorecalls.org/1991/431.shtml)
Doesnt specify RS or z28, only "camaro"
And this page says:
"There is currently no recall data available for this"
(http://www.internetautoguide.com/aut...let/camaro/rs/)
Id say call the dealer with your VIN, Ill have to do the same
Model Year: 1991
And this page says:
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
I have this problem with my 92 RS, I spent about a month trying to get GM to foot the bill for the repair. The GM dealership I took it too saw it was covered under the recall, I saw it was covered under the recall on several places that the recall was listed. And I was suffering from problems from the recall on my vehicle. However GM never issued a recall out for MY SPECIFIC VEHICLE so they would not foot the bill to have this repair done. I talked with several GM people that tried to help me out with this, the shop wanted the buisness and they tried. However unless you have had a recall issued out by GM for your specific vehicle that just didn't have the repair done (or even if it was checked When the recall was issued and the dealership decided it wasn't faulty they wont pay for it, even if it now obviously has the problem) when it was issued, they will not pay for it. It apparently doesn't matter if GM messed it up or not, they will do whatever they can to get out of paying for this. Not a big surprise, just know what to expect, I wasted a large amount of time on this for no benefit...
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Then you need to contact the proper authorites to enforce the laws and regulations. But this tank a problem seems to affect only 91 RS Camaros.
Look at the links I've posted on the first post.
Model Year: 1991
And this page says:
Model Year: 1991
And this page says:
Last edited by Psycho_91Camaro; Mar 19, 2006 at 04:20 PM. Reason: Automerged Doublepost
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I raed about the recalls on the gas tank thing for the 1991 firebird and about 2 years ago I went to local GM dealer in Miami, Florida and gave my 2 Vin numbers for both my '91's. One was a recall, they did crap, still smells sometimes and the other one they said had no recall, I still smell gas on it sometimes too. What should I do?????? Andy
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I just bought a 91 Z28 and it has this problem. I should get this done. My dad is a GM tech at a dealer. I shouldn't have any problems.
Originally Posted by 88txiroc
Stuck to the top.
NHTSA Campaign ID Number: 94V077000
Recall Data: 04/25/1994
Components: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
1992 CHEVROLET CAMARO FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Recall Date: 04/25/1994
Summary:
Consequence:
Remedy:
Notes: CHEVROLET CAMARO 92C36
Summary:
Consequence:
Remedy:
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My son's 91 RS was leaking around the top of the tank where the fuel lines go into it. The o-ring was pushed out of place and hanging down in the tank. The area where the o-ring was unseated was pretty dusty so we figured it had been that way for awhile. Not much of a problem till you fill the tank to the top. $9 o-ring and and afternoon later no more leak. By the way, that tank had some type of felt padding strips on the top of the tank as well. We replaced them with (you guessed it) strips of felt roofing material folded over 2 or 3 times to get comparable thickness.
Car: 1991 Camaro RS
Engine: LO3
That o-ring, is that the one where the fuel pump assembly goes into the tank ? My replacement one was real real thick, I keep wondering whether I managed to get it in properly or not *lol*
I think I'll just run out to the junkyards one of these days and get another tank, a pre 90 one, get the o-ring and cap etc, flush the tank, fill it with sealer, put some gas "friendly" epoxy around the filler neck just to be sure, andcall it a day.
I tampered with my gas tank, so I seriously doubt they would fix it for free anymore.
Car: 1991 Camaro RS
Engine: 350 stroker .40 over 11:1 comp
wow, good thing i deided to read this thread. I actually do smell gas when my tank is full, I will definately call the dealer first thing tuesday morning and see if this vehicle has already been serviced for this or not.
Car: 1992 Camaro Rally Sport
Engine: L03 305 E TBI
Transmission: M5
Axle/Gears: 3.08
i went reliable chevrolet today and talked to 3 different people all of them said that it not an open recall... obviously they just dont wanna foot the bill to fix it what do i do ahhhhhhhhhhhhh
http://www.autorecalls.org/1992/433.shtml
Car: 1991 Z28
Transmission: WC T5
I've yet to get around to doing mine, but the recall is outstanding on my car and my dealer will do it anytime.
It's a safety recall, and saftey recalls never close. Cause a stir the next time you go there, then ask for the service manager and ask him if you should give file a complaint to GM against the dealer or not.
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
IF THEY REFUSE TO DO WORK ON IT! AND ITS A SAFETY RECALL! BY LAW THEY ARE REQUIRED TO FIX THE RECALL PROBLEM!!! IF NOT YOU NEED TO REPORT THEM TO National Highway and Traffic Safety Administration!!!!!!!!!! GO TO THEIR WEB SITE!!! and there is a number you can call. ALSO ADVISE THE SERVICE MANAGER BY LAW THAT THE DEALERSHIP IS REQUIRED TO FIX THIS! AND THAT YOU WILL TAKE LEGAL ACTION IF HE OR SHE REFUSES! ALL IT TAKES IS SOME *****.
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
i have a 91 z-28 and the same thing happened. the dealer found this last february (05) and just told me i needed to get it fixed, they couldn't do it.
it was completely broken. the tank and neck came out seperatly. not doubt the BIG GUY was looking out for me.
Car: 1997 S10
Car: 91 camero RS
Axle/Gears: not sure (YET)
Thanks for the info i own a 91 RS and it will go to the dealer to be checked out i got the car from a buddy for free, the moron let the car sit for five years just because he drove the brakes clean thru the rotors, infested with bees and water, but a new batt some tranny fluid down the hatch and she fired right up, have fixed everything wrong with it just needs paint, she is starting to come into focus lots of time and love and she will be sweet. thanks again dhighway
Car: 91 camero RS
gas tank recall wont go unnoticed
The information on the gas recall got my attention, safety is top priorty with it will be checked by the dealer immediatly. I love this site and my 91 RS thanks again dhighway Supreme Member
Car: 1991 Camaro RS
Engine: LO3
I just got myself another gas tank (from an '88 Firebird), for free, with the TPI pump in it, and it's going into my Camaro after the smog check.
Car: 1989 Camaro Iroc Z
Engine: GM Goodwrench 350
Transmission: T-5 Manual
Man, I have an 89... when I bought it I smelled gas from the rear somewhere... then the fuel pump quit. I took it to have the fuel pump replaced and my mechanic noticed the filler neck seperated from the tank. I had it brazed back... I wish the recall was the same for my year, too. Would have saved me some money.
Car: 1991 Trans Am Convertible
Transmission: 5-Speed
Just got it back from the dealer..... with a brand new Gas Tank.
They did a smoke test on it and found the welds around the filler neck were bad and that it was indeed leaking gas. I filled it up and it didn't smell like a gas station.
In fact, I think my gas guage may actually be accurate now....... Time will tell on that though.
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
So when they do this recall you get a new tank and pump, and sending unit??? My gas gauge doesn't read right and this would just be too sweet
Car: 1992 Formula
Axle/Gears: 3:42
I just called today with my 2 vins and GM said nothing on file and no such recall for me to get. No wonder why they are losing there a#@ and Americans are buying foreign cars. Andy
Car: 1992 Formula
Axle/Gears: 3:42
I just got off the phone with NHTSA and they advised me too it goes for only 10 years after vehicle is sold and for specific vin, pretty nasty lady on phone I must admit, just becasue I have 2 16 year old cars does not mean I live under the expressway.
Both my cars have that smell, they are affected, but the consumer is getting scre#$ed here, don't buy any new GM is my point. Andy
