all about the timing
Old Dec 19, 2005 | 02:21 PM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
When I went to set the timing on my 2.8L V6 engine,I followed the procedure step -by step.The single wire connector was disconnected,(brown wire),the distributor was rotated to 10 degrees,retightened by friend so distributor would not move,engine shut off,then the wire was re-connected, engine started,check timing,timing still off, WAY OFF.
Any ideas?
Old Dec 19, 2005 | 03:01 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
After you plug the wire back up, it will be way off.
After distrib is tightened, check it again with the wire dx.
Plug wire back up n drive off.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
