water pump
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
water pump
how do i get past the power steering pump to get the water pump off? do i need to remove the whole pump? cuz i tried to just take the pully off of the power steering but its so tight the belt just slips. your help is appreciated...
Car: 1990 Camaro RS
Engine: 3.1L v6
ok i finally got past the ps pump and now i have all the bolts off the water pump except one! its one of the torx bolts and it is stripped out the a**. any ideas?
Car: 91 Firebird
Engine: 191ci 6cyl
Get a screw extractor, you can drill into the middle of the torx bolt where the threads are stripped then drill the extractor in there and hopefully take it out....
Car: 1987 Firebird
Engine: LB8, 2.8L V6
Transmission: t-5
You could also go cave-man style like I did. Grind the head right off, take the pump off. Then heat the thing up with a torch and grab on to it with some vice grips and yank hard. When I got mine out, coolant gushed out from the hole.
Car: Fox Body+Third Gen Cam
Engine: a few
Transmission: few more
HEHE...just got me a welder...nice to have extra options.
I didnt do it, but on the Lincoln I had, the mechanic told me he cut off the heads and then torched em, and threw water on them to try and shrink them. Did that a few times and broke em loose. Similar to what you are saying
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
