Washed now dont run
Old Feb 3, 2006 | 06:13 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Washed now dont run
Agg.. been one of thoes days.. went to a car wash.. and the engine died.. had to have it towed home.. have spark but wont run.. worst thing is I went inside to get some tools and the brats from down the street ripper out the plugs wires and damaged the cap.. AAAGGG!!! got new cap.. and reliezed I dont know the firing order.. So I could use the firing order and any ideas why it died in the 1st place..
Old Feb 3, 2006 | 07:14 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
WTF? Are you serious some little ****s came by and damaged your ride? Call the cops? Go beat the **** out of them?
Anyway, the firing order is 1-2-3-4-5-6, usually #1 is pointing towards the #1 cylinder, but you may want to pull the #1 plug and get it to TDC to verify.
Old Feb 3, 2006 | 08:05 PM
madathlon's Avatar
the kids have been a problem from day one.. there mother is a crack head and the PD do nothing about it.. but other wise thanks for the info
Old Feb 5, 2006 | 10:26 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Just walk down the street, walk up the first one you come to and punch him in the face as hard as you can then go back to your house. I doubt anyone on the street will take their side if they're that much of a problem and what's the mom gonna do? Smoke more crack? You should get a haynes manual for your car, it's just really good to have for looking up things like that, or torque specs....
Old Feb 5, 2006 | 10:34 AM
madathlon's Avatar
I have a chiltons on the way.. And I made the kids bike dissapper already last night ..
Old Feb 5, 2006 | 10:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You wanna get some evil revenge?
Anonymously leave some Muhammad cartoon Teeshirt on their front step. Then as the kids go running around wearing them, call the local news. teeshirt printer teeshirt transfer paper is cheap.
Old Feb 5, 2006 | 01:01 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
gumby what the hell are you talking about. why is the news going to care about a t-shirt bootleg?
you stole there bikes? i am in full support of that
Old Feb 5, 2006 | 06:31 PM
madathlon's Avatar
t shirts? naa.. most likly it rise some free speach B.S. and I really dont want to hear about some school having to allow them to wear them at school..
Old Feb 5, 2006 | 08:32 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
As far as the car died after washing, most likely you got some some vital sensors/wires wet, or got some water on/in the distributor. Check things out, dry out what's necessary.
Old Feb 5, 2006 | 08:35 PM
madathlon's Avatar
I let it dry out over night.. its running again.. I thought water in the dizzy.. but its was nice and dry.. So now in on to checking all the connectors to see if the seals have gone bad..
Old Feb 5, 2006 | 09:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Watch the news more often and you will know why. They just have been rioting and buring placed down for the past 2-3 days over that cartoon.............
Old Feb 5, 2006 | 09:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The one thing WD-40 was made for.....
Might wanna carry a can next time and spray things down ahead of time. Maybe even stick a small plastic bag over Dizzy befor washing.
[WD-40 = water dryer #40, invented for the military. Its not a cure all lube as advertised. But great for electroinc parts that get wet.]
Old Feb 5, 2006 | 11:43 PM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
Wonder if that'll work for a faceplate to a deck I love but cant use (it got left in a car's trunk, the trunk flooded...still works but the graphics are all screwed up)
Old Feb 6, 2006 | 06:22 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
probably already shorted stuff out in the face plate if it got wet and you've run it and things are messed up. Probably needs to be taken apart and repaired or something.
Old Feb 6, 2006 | 07:08 AM
ckjoshz28's Avatar
Not to get off topic but it stands for Water Displacement formula 40.
And to madathlon keep that dist. dry...
Old Feb 6, 2006 | 07:14 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How **** of you. Thanks for the life changing clarification.
#40 implies formula 40, as it took 40 tries to get something useable.
#40 was a success and who knows how many they came up with.
But I am sure you will tell us.
Old Feb 6, 2006 | 07:59 AM
ckjoshz28's Avatar
Sorry didn't mean to come off as a jerk...just wanted to correct the water-drying comment b/c it doesn't actually dry the water, it just displaces the molecules....if you want the chemical composition of wd-40 and the changes between 1 and 40 they are online as I found them for a report I did back in high school about it. Although it is quite boring.
Again sorry, no disrespect intended...
Old Feb 6, 2006 | 08:34 AM
madathlon's Avatar
1. There was no water in the dizzy.. 1st thing I did check..
2. Da.. yes I know what WD 40 is for..
3. I did have spark the whole time.. so Im thinking its something with fuel..
Intill I ether find a Fuel pressure sw or when I get my chiltons book here.. Or Unless someone here tells me.. Im going on the theoy thats a sensor/switch wea shorted my the water and not allowing fuel to flow..
So lets keep the the good info comeing.. Never hurts to hear ur thoughts..
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
kyleb24
Aug 15, 2015 08:24 AM
