Removing camshaft from 3.4l
Old Feb 5, 2006 | 09:05 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
I'm trying to remove the camshaft from my 3.4 and i can't get it out, it seems to be caught on the shaft from where the distributor is. i cannpt remove the peice in the whole , and i'm not familiar witht he 3.4 dis setup.
any help would be great, this is the third 3.4 i've bought and i've never had a cam in one, i'd love to ge tthe machining finished and this is really getting to be a problem.
i tried pulling it out with pliers and i couldn't and i tried unscrewing it but thats not helping.
thanks guys
Old Feb 5, 2006 | 09:13 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I never removed the camshaft on my 3.4.
I did on my 2.8 and 3.1 and had no problem removing them thru the front after the distrib was out.
The hex rod down the back comes out fairly easy with some needle nose if your saying you think that is the problem.
Old Feb 5, 2006 | 11:53 PM
Thunderfest's Avatar
Did you pull the sensor out firs off the side of the block?
Old Feb 6, 2006 | 01:24 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
no i didn't, i tottaly forgot about the cam sensor
Old Feb 6, 2006 | 05:42 AM
Dale's Avatar
Engine: 350 S-TPI
That would be top of the block. And IMO, dont see how that would keep it from coming out.
Old Feb 6, 2006 | 11:06 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
cam sensor's gotta come out because it'll probably catch on the lobes and/or journals. the dumby dist. HAS to come out before the cam will come out. you are hitting the gear on the dist. on the rear cam journal...the cam will not come past it. that dumby distributor can be tough to get out but i'd try getting a flat head screw driver under the edge of it (after the clamp is off, of course) and twist/pry it up. you might need to put some penetrating oil on it and let it soak a little to help break it free but you do have to get it out of there.
Old Feb 7, 2006 | 12:31 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
The oil pump drive, pulls straight out the hole. Yes it's a PITA, yes you'll curse and swear, but it will come out. Get a flat head screwdriver between it and the block, then pry up.
Old Feb 7, 2006 | 07:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
perfect guys thanks, i figured it was just a pul out, but i didn't wanna screw up the block.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
