Agg.. Wierd problem
Old Feb 11, 2006 | 04:36 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Agg.. Wierd problem
Ok Yesterday I went on a small trip from my place to lakehead.. ABOUT 80 MILES ROUND TRIP.. So as Im pulling up the off ramp heading home it dies on me as I come to a stop.. and when I restart it it wouldnt build up RPMs.. and keeped dieing.. Oil pressure is about 70PSi water temp about 200F and 3/4 tank of 89 oct gas.. But it was acting like it was way over heated.. let it cool for a bit restarted and drove home.. But now its really ruff.. dont like to idle but once warmed up its ok.. idles good 2 850RPM and Im no longer getting any engines code.. just replaced the MAF, Temp sensor and the O2 sensor.. Any ideas would be helpfull..
Old Feb 11, 2006 | 10:40 PM
Thunderfest's Avatar
Its is possible that the Ignition module inside the distributor is starting to act up. Really isw a crap shoot right now from what you are discribing. Could even be the fuek pump. But it definately should be something electronic getting heat soaked.
My suggestion would be to start with the ICM (Ignition Control Module) and rule that out. It is fairly easy to remove from inside the distributor. You can take it into Autozone and they have a diagnostic machine behind the counter that can test it for free on the spot.
If it is bad, I would ask them for an AC Delco replacement unit. I doubt they have it. They carry junk ones like Wells brand. Just decline their offer for a new one and tell them yopu will find a Delco uniot from somewhere else since they do not have it.
Old Feb 12, 2006 | 09:33 AM
madathlon's Avatar
So im guessing that this part not moniter by the ECM.. I'll pull it and have it checked.. thanks on the tip..
Old Feb 12, 2006 | 10:36 AM
The ECM is said to supposedly send a code if certain parts go bad, but do not rely on that. Early years of OBD1 cars will not show codes for problems such as a faulty ICM, pickup coil, or EGR and such. I have an '87 and have never had codes for either of those and have had each of them go bad at least twice over years of owning this car.
I have heard plenty of people say thoughthat the '90-92 (I think those are the year range) with the electronic EGR's will show a code, but I have yet to hear of a vaccuum controled EGR V6 to show a code for that faulty part even though the manual says it should.
Old Feb 12, 2006 | 10:40 AM
madathlon's Avatar
Ya.. Im learnin that.. I just bought this car about a month ago and finding out its been running basicly without any sensors working.. I so far have replace the MAF, Air temp, water temp, O2, Speed sensor.. now looks like the ICM.. LOL.. Im still wonder how it was running in the 1st place.. I did drive it home..
Old Feb 13, 2006 | 06:41 PM
madathlon's Avatar
AAAAGGGGGGGGG!!!!!!!!!!!
Change the ICM and there no change!!!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
