what can go wrong will go wrong
Old Feb 19, 2006 | 06:32 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
i was hoping to get the 3.4 and trans in the car today, but nooooo, the clutch disk i have is 1/8" in diameter to big for the pressure plate, it hits the brackets that have the bolt holes to bolt it to the flywheel, woo, so far i had to find the hard way
- need my 2.8 timing cover and water pump for v belt set up
- needed 2.8 oil pan to match timing cover
- napa auto parts sucks as muchs at getting stuff right now as it did when i worked there.
WED. the 22nd, it will be in weather permitting, ha, figures, 3 days after i fix my trans for a busted shifter fork, a rod bearing dies.
Old Feb 19, 2006 | 06:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
My type-up told you about the timing cover, waterpump, and oil pan.
As for the clutch disk, WTF? Did you go get a new one, or re-using your old one? What did the flywheel come off ?
Napa, as well as any parts store doesnt always have everything in stock, esp for our v6's.
Dont feel to bad, my car still isnt fixed from 11-3-05.
Old Feb 19, 2006 | 07:29 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Originally posted by Dale
Dont feel to bad, my car still isnt fixed from .........
the day I bought it
Old Feb 20, 2006 | 01:37 PM
Car: 1986 Firebird
i read about the timing cover and water pump being reverse rotation, i didnt catch the part where the 3.4 pan didnt match the 2.8 timing cover, but i dont see how i missed it, its so obvious. and yea, a new clutch set from napa, clutch disk was too big for the pressure plate, i got a flywheel from a 3.1, the pressure plate bolted up, but yea, no go on the disk itself. and i never said napa doesnt have what i need, i know that, but when they get the parts from warehouses, its not the right stuff, or its defective.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
