turbo install /w pics
Old Mar 27, 2006 | 10:50 PM
  #51
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
well on our old hondas, we would find the shortest line for the charge pipes to go from turbo - intercooler - intake. and we would cut away at the front end to get it to fit. so that way pressure doesnt drop...... alot anyways. plus it looks bad ***
Old Mar 27, 2006 | 11:08 PM
  #52
daves12secV6's Avatar
im nto worried about presure drop, the turbo im using can make more boost then the engine can handle,about 10-12 more psi
Old Mar 28, 2006 | 02:10 AM
  #53
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
man, thats like scrounging for pennies when there are twenties lying around. any gains were purely pyschological.
Old Mar 28, 2006 | 09:28 AM
  #54
Six_Shooter's Avatar
Transmission: 5-speed/T-5
That's pretty much what I was thinking.
BTW nice analogy.
Old Mar 28, 2006 | 02:55 PM
  #55
no actually the shorter the compressed air has to travel, the quicker your turbo can spool. but thanks for the input
Old Mar 28, 2006 | 03:02 PM
  #56
Naft's Avatar
true, but if you notice, i didnt actually say that it didnt do anything, i said it totally wasnt in any realm significant. I'm not saying it isnt wise to plan the best route for your intake piping to minimize bends and pipe length, but jeapordizing the structural integrity of your car for what adds up to at the most maybe 10 ms of spool time doesnt make much sense to me.
and sorry if i came off as a jerk, that wasnt my intention.
Old Mar 28, 2006 | 03:12 PM
  #57
no its cool, not even bothered. we wouldnt take anything away that didnt need to be there. so along with cutting holes, we would also weld in additional support aroung where we cut.
Old Mar 29, 2006 | 11:40 AM
  #58
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Leo is correct - the shorter the intake path, the better the throttle response.
Go compare a stock 7MGTE vs a FFIM (forward facing intake manifold) 7MGTE. The difference is VERY noticeable.
Do not run your pipes unnecessarily longer than they need be, and shortening them DOES increase throttle response.
Old Mar 29, 2006 | 09:42 PM
  #59
Thanks alot doward, i knew i knew what i was talking about. because we tried it both ways, and we found it alot more responsive.
Old Mar 29, 2006 | 10:14 PM
  #60
well from what i have planed ive got 2.5 inch pipe from turbo to the intercoler that run will be liek 2 ft long, 2.5 pipe from the intercooler to the throttle body,but that will be about 4 ft long,
the other way i have planed to run the pipes will be alot shorter prolly 50% but would leave me much less ground clearance and wont look as good
Old Mar 29, 2006 | 10:24 PM
  #61
cool, sounds good....thats not alot of pipe at all, we would have to use more than that back in the day... throttle body was near fire wall.... good luck.
Old Mar 30, 2006 | 08:13 AM
  #62
Doward's Avatar
Dave, sounds similar to mine... If you are sticking with a draw-through MAF, my suggestion would be to convert to Speed Density... OMFG THE THROTTLE REPONSE ++!!
I know that's not a very Mod-like response... but seriously, NIGHT and DAY difference.
Old Mar 30, 2006 | 11:48 AM
  #63
^^^ LMAO
Old Mar 30, 2006 | 02:25 PM
  #64
maf_setup_for_non
ps_at_work_keyboard_broke.
some_jackass_spilled_coffe_in_it
now_spacebar_dont_work
Old Mar 31, 2006 | 01:18 PM
  #65
im_in_a_very_good_mood
just_scored_this_on_ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
Old Mar 31, 2006 | 01:28 PM
  #66
LOL, if you get more than about 10 miles out of it, consider yourself very lucky.
Old Mar 31, 2006 | 01:34 PM
  #67
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
I'm assuming from your profile that you are Raven, and therefore you generally know what your talking about so why do not think he will be lucky to get 10 miles out of it? It looks to be in awesome shape.
Old Mar 31, 2006 | 03:21 PM
  #68
Naft's Avatar
try searching for xs_power. or ss autochrome
Old Mar 31, 2006 | 04:09 PM
  #69
QFT!
XS Power is just a new name for SS AutoChrome......
Most people that used those turbos found that they were nice paper weights, after only a few miles.
Old Mar 31, 2006 | 06:13 PM
  #70
QFT!
thats so true, crappy manifolds, crappy turbo, bad company... stupid ebay for allowing companys that sell bad products to continue for so long, ive heard of manifolds not fitting flat against blocks, and turbos not being balanced properly. good luck none the less
Old Apr 1, 2006 | 01:19 PM
  #71
hmm i didnt know that, every bad complaint i find is th eone that refers to the oone turbo were the housing split into 2,ther biggest bad thing i do see is that ppl complaining that the seals leak, well its to late now since i already bought it.but i know a shop that can rebalnce the wheels/shaft for me.
do there turbos use standard garret parts, if so i have a full t3/t4 rebuild kit,**** nm the turbo i bought is a ball bearing turbo,so id have to buy another kit
Old Apr 1, 2006 | 08:33 PM
  #72
As far as ive heard, everything size wize, its ok, but you might also want to look at the compressor wheel, everyone i have ever seen seriously look like plastic.JUST CHECK....
Old Apr 2, 2006 | 12:29 AM
  #73
well i will go thre the whole turbo,if something dosent look good i will replace it,even if i have to replace seals or a wheel it will still have cost me less then buying like a turbotechnics turbo etc
Old Apr 2, 2006 | 10:39 AM
  #74
true
Old Apr 3, 2006 | 12:52 AM
  #75
just an update, the turbo was planed to go in this comming weekend, but on friday night me and the gf drove to island dragway,and proceded to burn up the trans,so this wweekend will be a trans swap,and the follwing weekend will be the install weekend
only got to make one pass and it was bad didnt even make it ot the 1/8th went liek 12.08@59
Old Apr 3, 2006 | 01:13 AM
  #76
You should do stand up.....
Check for a post about SSAC from a member called 89jyturbo. The thread should be in the power adder forum.
Old Apr 6, 2006 | 06:28 PM
  #77
this project very sadly officially dead due to the fact i no longer have the car, so im on the lookout for another rs to buy to finish this project
Old Apr 6, 2006 | 07:42 PM
  #78
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Did you crash it or something??
Old Apr 6, 2006 | 08:07 PM
  #79
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
whaaa!. fire or something?!?!
Old Apr 6, 2006 | 08:26 PM
  #80
no the car is perfect other then a minor transmi9ssion problem, i brokew up with my gf,which the car is in her name,there is no chance of me getting it back cause she is pissed at me.so i am curently looking for a new v6 car,may possibly get rid of one of the v8 cars for the right v6 car.this time around im going with a fully built 2.8 including a gmpp light wieght racing block,which i will order once i find a new rs
Old Apr 6, 2006 | 09:26 PM
  #81
Ill trade you mine for that 5-speed Iroc... You can even keep the engine if you want...
Old Apr 6, 2006 | 09:34 PM
  #82
that may be a possibility, right now i have a line on a 92 with a 3.1,that i have to check out,ill let u know once i know whats going on with this deal
Old Apr 6, 2006 | 10:35 PM
  #83
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Your lucky you broke up now instead of later.
Girls are never forever. Just because they are all nuts and can change their mind widly for no reason.
never mix cars or friends with girls.
Cause ya don't wanna see her riding around in or on either after you break up.
Old Apr 7, 2006 | 04:21 PM
  #84
Car: 1986 Firebird
now all your money can go to mods! i told my gf i like my cars and if she has a problem, too bad. you dont need a high maintnence car AND gf at the same time
Old Apr 9, 2006 | 02:57 PM
  #85
well looks liek i will be pulling the stroker engine from my 86 iroc and droping in a 2.8 or 3.1 to turbo,since i cant find another rs,on the plus side ill already have the v8 suspension and **** that i would have had with the old rs
Old Apr 12, 2006 | 06:05 PM
  #86
well i have great news I GOT THE RS BACK
so this project is once again alive and kicking, all work will resume the last weekend this month after i show the car at the cops and rodders car show
Old Apr 13, 2006 | 10:26 PM
  #87
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
How did u manage to get it back? I hope u bought it off her. Cuz it wud suck u finish, and she decides to split again.
Old Apr 14, 2006 | 06:32 AM
  #88
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
Let me guess:
The car needed work (trans etc.) and it was modded -> high maintenance. Your girlfriend being a typical woman can't really maintain the car herself and taking it to a mechaninc would cost a ton of money, so she kindly offers you the car ?
Old Apr 14, 2006 | 10:53 AM
  #89
Originally Posted by molopaa
Let me guess:
it was mine to begin with,since my liscence is suspended,the car was in her name cause the buick she had died,we had been dating over 2.5 years,we got into a hu8ge fight and she was being a bitch and wouldnt give it back.but thats all taken care of now
and actual;ly she could swap the trans herself,she is very mechanically inclined,everyhting from matnince to performance mods
Old Apr 14, 2006 | 12:10 PM
  #90
molopaa's Avatar
Engine: 2.8 V6
Wow, a chick who is skilled in mechanics, that's rare. Good thing she gave you your car back.
Old Apr 14, 2006 | 04:43 PM
  #91
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Not a honda, but even the V8 guys do not want a piece of this guy...
Shepherd Racing - Your DSM transmission specialist! yes, that is 7.976 @179.06 in a AWD car. And yes, that is the current world record holder for an AWD platform.
and even has the vid...
Old Apr 17, 2006 | 02:06 AM
  #92
Bluechrome's Avatar
I'm not trying to be a jerk and I don't want to stirr up a pot of sh** between the domestic faithful and the import crowd, but why the hell would someone want to dump that much work/cash into a Talon?!! You could get a domestic into the 8's for half of what he probably spent. I have to give him credit because it must've been hard to get it to hook with awd, but I'd rather stick with a good ol' rwd american car so I can without looking like a jackass. That said, I'm still deciding between turboing my 2.8 or going with a 350 so keep the pics coming this looks like a fun project.
Old Apr 18, 2006 | 04:51 AM
  #93
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Originally Posted by 69charger383
I got a second gen Supra turbo laying around that I could prolly sell you for $100 plus shipping or something like that... Pretty sure its the same turbo Doward is running... Not positive tho
Nope. Doward's running something obscenely non-stock now.. I'm running a MKIII Supra CT26, and it's a bit big for a 2.8l
Old May 2, 2006 | 03:40 PM
  #94
Cyrix_2k's Avatar
any updates?
Old May 2, 2006 | 04:11 PM
  #95
yeah the turbo i bought ended up having a bent shaft,so im about to buy a new one once i figure out the optimal turbo to run,though i will be starting work on the headers,and some of the other turbo realted work,come next week.was on hold till the cnr car show and the swap meet which was this past weekend
Old May 2, 2006 | 10:48 PM
  #96
LMAO..... some of the greatest racing i have ever seen were AWD DSM's, You would have a harder time getting traction in a rwd , then awd. oh daves89rs, i have a friend who turbo's vipers here in houston, figure out what snail is needed, and i can talk to him about getting a good turbo, no ebay involved, it would have a receipt.
Old May 2, 2006 | 11:06 PM
  #97
t04e stage 3 50 or 60 trim .48 or .63 ar cold side
Old May 2, 2006 | 11:31 PM
  #98
ill call him tomarrow.... he works for RSI here in houston, im sure you can look them up.... good reputable shop, he the custom manifold/turbo guy, so ill let you know. he is the one who i dabbled with , the hondas.
Old May 2, 2006 | 11:32 PM
  #99
thnx
Old May 2, 2006 | 11:36 PM
  #100
so you guys can see this craziness....
Attached Thumbnails turbo install /w pics-viper1.jpg   turbo install /w pics-viper2.jpg   turbo install /w pics-viper3.jpg
