turbo install /w pics
Old Mar 4, 2006 | 12:42 PM
daves12secV6's Avatar
AND IT BEGINS
After going with a na 2.8 for a while and getting into the low 15,s off the nitrous ive decided that i wont get much more out of this motor without turbo/supercharging
current na motor specs
2.8 v6
Ported intake
Custom ram air kit
Wild cam 248/258 @.050 500/520
custom chip
ported and milled heads
10-1 compression
low temp stat
3" ex system
and msd 6al
and a 100 shot of nitrous but i never made it down the track using it
new motor specs are as follows
2.8 v6
ported intake
stock cam ( old one has to much overlap to be any good with turbo
custom chip
new heads/stock with wild porting/but not milled for added compression/
thicker head gaskets to lower compression even further
custom turbo manifold/headers
sbc 327 small journal rods
low temp stat
4 " spintech ex system
msd btm
25 shot of nitrous
fmic
and 1 buick regal turbo
This weekend im going to pull my curent heads and drop the new heads on / swap out the cam and pull the oil pan to weld in a fiting for the oil return for the turbo. Get the msd installed.And get the front cross member notched for the downpipe.
Old Mar 4, 2006 | 12:46 PM
so far ive goten the heads and oil pan off / and the cam swapped. but i forgot that we had milled the intake down to match my milled heads, (if u mil the heads and not the manifold base it will not seal/leak). but luckily my local junkyard has a lower manifold But i wont get it till monday.
I got the an fitting in the oil pan.
tom i will install the new heads and oil pan and get some pics
Old Mar 4, 2006 | 11:09 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Definetely get the pics!
Old Mar 5, 2006 | 05:24 PM
well i got the new heads installed,and the oil pan back on today,still dont have the manifold base,ill have that tom afternoon. but it all took longer then expected so i didnt get a chance to notch the front x member for the down pipe today,
forgot my digital camera at home,but i went out and bought a disposable camera and took pics.ill have those tom to post
after driving my iroc again for 3 days ill never complian to myself how bad the rs is on gas again lmao
Old Mar 5, 2006 | 09:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Old Mar 5, 2006 | 10:41 PM
relax gumby there comming,(besides only thing ive really done so far is swap my milled heads for a stock set and swaped back to stock cam// figured the actull turbo stuff would be more important) i ran outa the house so fast this morning i forgot the digi camera, i got pics but there on a reg camera, ima drop the film off to get developed tom and put on a photo cd
Old Mar 10, 2006 | 06:14 PM
ok i havent had time to get anything else done yet, on the car,and i took apart my turbo to go threw it,needless to say it was time for a rebuild.Ill have the rebuild kit on monday or tuesday.but i did manage to get the housings glass beaded and cleaned, and i made a new flange to plug the stock wastegeate hole,since im going to be running a external wastegate.heres a few pics,ill be taking mor epics as i do more work on the car tommorow
Old Mar 10, 2006 | 06:21 PM
figure i should throw in a price list ifor the ppl that wanna try this themselves.
#1 used turbo off ebay - t3 from buick regal .82 ar hot side .48 cold side 87$'s
#2 t3 rebuild kit complete (ebay) - 65$'s
#3 intercooler (ebay) #40$'s
#4 BOV (ebay) 43$;s
#5 external waste gate (ebay) 73.55$'s
#6 universal intercooler piping kit (ebay) 85$'s
#7 ex manifold (junk yard) 25$'s
#8 msd btm (ebay) 100$s
#9 laptop for dataloging/tunning (ebay) 31$'s
everything else i had at the shop already so ill get the prices for everything else when the build is complete
Old Mar 10, 2006 | 07:46 PM
btw stainless steel is a ****ing pain in the *** to work with,took me a while to bore the hole in it for the down pipe
Old Mar 10, 2006 | 09:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hey your the oone who pic " /w pics" in the title.
glad to see you finally get some.
Id toss some 1000f powder on that housing
Old Mar 11, 2006 | 06:28 AM
gumby there will be lots of pics,i thought i would get this work done farly fast,but thats not gonna happen,still gota get the one roll of film developed.but ill keep posting as i do lil by lil,ill have some more pics today as im gonna do more work,
what do u recomend that i use for coating,that i can buy at an auto parts store,i was just gonna leave it glassbeaded,and not coated since its gonna be covered by a stainless steel heat sheild
Old Mar 11, 2006 | 01:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well I believe on a turbo you want heat in the pipes? right?
why they ceramic coat the piping, it holds the heat inside the pipe. Also keep the piping cool to the touch.
though on the turbo main housing and its thick cast metal. Id use powder coating on it. Powder creates a thermal bond that cools better then bare metal. Plus it looks nice.
I can get ya hook up for diirt cheap on both.
Old Mar 11, 2006 | 07:30 PM
not at this time gumby i have a car show to atend in less then a month, so im on limitied time table here maybe after the show i can take it all back apart and get it done though,
ps i got tons of pics today ill post them when im done eating
Old Mar 11, 2006 | 09:05 PM
some fo the things i got done today
starting to m,ake my new colant overflow can,since i have to remove the stock plastic one to fit the turbo
4 inch aluminum tubing polished in the lathe
with an end cap welded on
finished tank with fittings installed
my mounting location before install
installed
Old Mar 11, 2006 | 09:10 PM
top shot
hoses installed
another
shot from below
Old Mar 11, 2006 | 09:17 PM
airbox reinstalled
strut tower brace cllearance
another
brackets
holes in strut tower
installed and painted
Old Mar 11, 2006 | 09:22 PM
turbo
another
Old Mar 11, 2006 | 10:49 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
lookin good
Old Mar 11, 2006 | 11:52 PM
Doward's Avatar
It's a good start, lets see how it progresses!
Old Mar 12, 2006 | 11:11 AM
its progressing surely but slowly,we got real busy at the shop,since its race is starting up, so im down to 1-2 days a week to work on it,
btw strut tower braces are now availlible for sale
75$ each in red or black for 2 point bars
or 135$ each for 3 point bars in red or black
will only sell with 5 orders at a time (keeps costs down)
Old Mar 12, 2006 | 11:46 AM
doward plz edit my previous post i caculated costs wrong
with 5 orders at a time it will be 100 for 2 pt bars
150 for 3 pt
with 10 orders at a time it will be 75/135 respectivly
and delete this post after u edit for me plz thnx
Old Mar 19, 2006 | 12:55 PM
i just got my new bov and this thing is huge
btw if everything goes ok this week i will be finishing the install this comming weekend
just waiting on my 3.6 psi waste gate spring
Old Mar 19, 2006 | 01:02 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Good to see another turbo going in. Keep up with the pics!
Old Mar 19, 2006 | 03:24 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Is that a Turbo XS type S BOV?? I was wondering cause Im probably getting the Turbo XS type H for my build and their the same size from what I hear...
Old Mar 19, 2006 | 04:11 PM
no its not
http://cgi.ebay.com/ebaymotors/ws/eB..._BIN_Stores_IT
theres a link
i only paid 28 for mine from the same person just look if he has any up for auction instead of buy it now
extreamly fast shipping and excelent customer service
Old Mar 19, 2006 | 04:14 PM
Not bad man... After we finish our builds we should meet up, I wouldnt mind driving down to Jeresy to see another built 660
Old Mar 19, 2006 | 04:20 PM
e-town camaro-transam vs mustang event maybe ?
Old Mar 19, 2006 | 04:21 PM
When is it??
Old Mar 19, 2006 | 04:31 PM
lol nm i only see one on the schedual and its april 1st,ohh and aprill 22nd ill deff be ready by then,may 13th, seems to be the last one,though the imopt vs us muscle wars are nice events,get to beat up on some iports all day lol,those run threw out the season,usually 1-2 a month
Old Mar 19, 2006 | 04:33 PM
Damn It woulda been nice to see some V6 Camaros whoopin up on Stangs... lol Im gonna check LVD to see what they got planned
Old Mar 19, 2006 | 04:36 PM
whats the time frame on ur build, im looking at 1-2 weeks till complete install,(stil driving the car everyday while doing this install lol hopefully 1 weekend is enough to install all the major stuff) that leaves me time to get the tune sorted out for the aprill 22nd event,and the following weekend ill have the car in the car show at the swap meet
Old Mar 19, 2006 | 04:39 PM
I wanna finish by April 15th... So that leaves me with what 3 weeks??
Old Mar 19, 2006 | 04:41 PM
if u finish in time u gota come out for the swap meet/car show last weekend in april
Old Mar 19, 2006 | 04:45 PM
I guess I could.. Would there be any racing going on that day or just the swap meet and show?
Old Mar 19, 2006 | 04:50 PM
huge swap meet and show its sat and sunday,the only day we can show is on sunday,better day to buy stuff is saturday though
Old Mar 19, 2006 | 04:51 PM
Im not really interested in buying things so Ill prolly just show up for the show..
http://www.etownraceway.com/main/schedule.htm
Old Mar 19, 2006 | 05:43 PM
84TransAm305's Avatar
Car: 2001 ram (prev 84 and 93 ta)
Engine: 360 (cold air, exhaust)
Transmission: plastic stock dodge....
Axle/Gears: ...havent looked that far....
daves89rs your flippin mad sir!!!!!!!!
but on the other hand holy crap, some kid made his LG4 a turbo too, lets put it like this when he says its a lg4 and lines up, the poor kid next to him doesnt realize what the hell he got himself into
thats gonna be the same with you, your just gonna line up say its a v-6, then BANG that things gonna move
good luck to ya
Old Mar 19, 2006 | 06:33 PM
Old Mar 19, 2006 | 08:34 PM
gota love ebay,just scored a better external wastegate then the used one i had ,for 70$'s new ex wastegate,to bad i cant find any cheap 2.5 inch stainless tubing id love to do a full stainless ex system,as of right now the down pipe from the turbo to the y pipe will be stainless
hey techsmurf
in this pic
what is the pipe comming out the back going to?
Last edited by daves12secV6; Mar 19, 2006 at 08:39 PM. Reason: Automerged Doublepost
Old Mar 20, 2006 | 11:21 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
HOw much horsepower do you think you car will be making after the install? Just wondering, woudln't mind turbo'ing my 6 with a lil more time and money...
Old Mar 21, 2006 | 11:40 AM
  #42
not realy sure ive goten an estimated 215 hp from the motor without the turbo, and one person has goten 350 rwhp with 9psi out of a 3.4 motor. im quessing 300 hp shuold be about right for a 2.8, but it could be more could be less.all depends on what else is done to the engine. once mine is done im gonna have mine dynoed
Old Mar 22, 2006 | 11:48 PM
  #43
ok i have an emergency. i rebuilt my turbo today,everything was perfect.Till i went to install the turbine shaft.ITS ****ING BENT. i didnt ntice it when i took it apart cause the bearings were so worn it had tons of free play, and it didnt bind up. so does anyone here have any turbos i.e doward/techsmurf amyone really, that they wanna sell me . or know were i can get a new shaft with the right hot side whell for my turbo, the turbo si off an early buick regal with a 3.1, .82 ar hot side .42 cold side. i need something asap
Old Mar 23, 2006 | 12:05 AM
  #44
if not is this a decent turbo to use ????
http://cgi.ebay.com/ebaymotors/T3-T4...QQcmdZViewItem
Old Mar 23, 2006 | 01:02 AM
  #45
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
a little big for a 2.8 maybe, but with ported heads it should be okay. not 100% sure cause i never looked into turbo sizing for the 2.8, just a 3.4.
Old Mar 26, 2006 | 02:14 AM
  #46
I got a second gen Supra turbo laying around that I could prolly sell you for $100 plus shipping or something like that... Pretty sure its the same turbo Doward is running... Not positive tho
Old Mar 26, 2006 | 12:41 PM
  #47
forgot to update,i bought a stage 5 to4 thing flows 65+ lb's and im also buying another turbo like the one i have already this one is made for the pontiac 301 motors instead of the 3.8
heh i tested my blow off valve the other day with an air tank filled to 8 psi and *** dam is that thing ****ing loud
Old Mar 26, 2006 | 07:17 PM
  #48
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
i really cant wait to see this finished, really wondering what everything will look like. good work.good luck.
Old Mar 26, 2006 | 07:26 PM
  #49
thnx
leo ur not the only one,lol im not sure how to run all the inlet pipes to and from my intercooler yet,the only thing i know for sure is the turbo is mounting driverside infront of the motor, soon as i get th enew turbo in, this is going to gether.Right now its taken about 1.5 weeks longer then i had originally planed, only cause this car is a daily driver, and i only get to work on it 1 day every weekend, though the final install day ill prolly take 2 days
Old Mar 27, 2006 | 10:39 AM
  #50
cool, lots of pics when finished.
