turbo install /w pics
Old May 2, 2006 | 11:37 PM
  #101
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
2 more
Attached Thumbnails turbo install /w pics-viper4.jpg   turbo install /w pics-viper5.jpg
Old May 2, 2006 | 11:48 PM
  #102
daves12secV6's Avatar
nice
Old May 3, 2006 | 11:17 PM
  #103
any chance u got to talk to that guy today?
Old May 5, 2006 | 01:43 AM
  #104
sorry ive worked almost 30 hours in the past two days, im off tomarrow(today), ill call him...
Old May 5, 2006 | 07:49 AM
  #105
damn @ 30 hours,i know how that is though ive been avg 10-13 hours a day at work,alright just let me know what u find out
Old May 5, 2006 | 09:46 AM
  #106
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just noticed this post! Cool project, daves89rs! You and the other 2 turbo guys will have to shoot it out one day on the track!
[the rest of us will watch]
Old May 5, 2006 | 12:18 PM
  #107
thnx
that would be fun having the 3 turbo cars go at it,when i started this project,i didnt relise how much work this was actually going to be,and thought i was gonna have this finished almost a month ago,well that and working many hours a day now hasnt left me much time,but its comming along slowly,hopefully by the end of this month i should be done.
one other thing this car is a daily driver and gets driven everyday while all this is being done which makes it take alot more time.
Old May 6, 2006 | 12:33 PM
  #108
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Dont feel bad man I was hoping to have mine done about a month ago as well.. Then I went broke spending all my money on this damn FWD head swap... Atleast you can still drive your car, mines all aprts in the driveway..
Old May 6, 2006 | 12:43 PM
  #109
Six_Shooter's Avatar
Transmission: 5-speed/T-5
when i started this project,i didnt relise how much work this was actually going to be,and thought i was gonna have this finished almost a month ago.
Can I say it? Can I say it?
Old May 6, 2006 | 12:55 PM
  #110
go ahead
dont get me wrong though i knew it was gonna be a bit of work
but its deff a lil more then i expected
Old May 9, 2006 | 09:04 PM
  #111
woot work resumes once again this weekend,though id like it to be on the engine,ill be swaping the trans for full manual 700r4,and prolly getting the 3 inch spintech ex system on
Old May 12, 2006 | 06:08 PM
  #112
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Well, that's very familiar
So is mine
Old May 13, 2006 | 09:54 PM
  #113
well the new trans is in,and i must say dammmnnn what a diff,though i used trick shift instead of reg trans fluid,so the shifts are a lil to harsh for street driving(locks up rera tires on downshift if i downshift early,and the converter needs to be lossened up a bit more,the one thing im not pleased about is im not able to hold 4th gear under wot,anyone happen to know if anyone makes a valve that alows wot 4th gear operation,right now its got the 3/4 valve.
Old May 14, 2006 | 12:27 PM
  #114
oh i almost forgot after i did the trans yesterday, i was poking around and found a place with a good price on a t04e stage 3 57 trim turbo .63 ar hot side and .50 ar cold side.so i bought that last night woot.i shoudl have it by friday this week.though this turbo isnt an all out drag turbo its hsould do very well for street/strip driving.it was figured that this turbo could put out about 15-17 psi on the 2.8 before it falls flat on its face.not to mention as i can prolly spool this turbo on the foot brake and leave the line under boost.as to were the t61 prolyl wouldnt spool until 3.300 rpm,though that turbo was capable of making around 25 psi+ on the 2.8
Old May 19, 2006 | 07:23 PM
  #115
ok just another late update this past wensday i bolted the slicks on the car/and put the 100 shot of nitrous back on.then i find out that it was raining at the track so i stayed home.left the slicks on the car.and headed out to a fbody club meet at night.well im stuck at a light and as it turns green i start to pull away from the light and bam. the engine shuts off.the dam timming chain snapped.
right now i have no idea if the engine is any good.but i shoudl know sometime late sunday or early next week.ill get the new timming chain on and do a compression test on all cyl's/and a leakdown test of each cyl to see if i bent any valves.if the motor turns out to be junk. i may go get a 3.1 longblock to swap in
Old May 19, 2006 | 07:49 PM
  #116
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
you shouldnt have any bent valves, these arent interference engines. you should be good to go with a new chain.
Old May 19, 2006 | 08:10 PM
  #117
thnx man i wasnt sure if the 2.8 was an interference engine or not
Old May 20, 2006 | 11:10 AM
  #118
once again alive and kicking,that old chain must have been really streched cause the car deff runns even better now.
im going to look into possibly getting a one off gear drive made or possible being able to retrofit a gear drive off another engine onto the 60* v6
Old May 20, 2006 | 12:03 PM
  #119
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
One of the guys I work with put a "quiet" Pete Jackson gear drive in his Monte Carlo SS. That thing makes the most annoying sound I have ever heard from a car. I'd stick with a good quality chain if I were you.
Old May 20, 2006 | 01:03 PM
  #120
Yeah I will NEVER use a gear drive, too much transmitted harmonics from the crank to the cam. It seems that anybody who uses one at some point breaks a cam shaft.
Also look at all of the top power engines out there, NONE of them use gear drive, MOST will use a belt, and the remainder will use chain.
Old May 20, 2006 | 02:56 PM
  #121
we use gear drives on all our dragster engines,never had a cam break.though my friend had a gear drive in his camaro the cam did break in that but it also kicked a rod at the same time,so im really not sure what caused the cam to break.
id love to use a belt drive.but jesel gets way to much money for one.an dim sure a custom belt drive would be even more exspensive
edit and btw the floating idler gear geardrives are horrible.i.e pete jackson/proform.the milidon etc drives arent that bad with the fixed idler.
Old May 25, 2006 | 09:26 PM
  #122
its going down this weekend by this time monday the car should be back on the road with the turbo installed.
and on wensday will be the first time im taking it to the track
hopefully all goes well and ill have tons of pics and some great track times to report back
Old Jun 5, 2006 | 10:39 PM
  #123
just an update i had goten the turbo installed and ran into a few embarasing problems.thus of which have been fixed.i have tested the car @ 8-9 psi with an 12-1 fmu and 17# injectors and run into a lean condition up high rpms.
before i had fixed the problems i had decided to go ahead and spend the money to twin turbo the car and sell it(car is no longer for sale but i did get offers in the 5k+ range).would have been easier to twin turbo then to fix the ex problem i was having.well my parts arived today.so the single turbo setup is getting changed into a twin setup.i bought a second t04e stage 3 57 trim,second 38 mm wastegate,and a large dual inlet fmic.so all of this is gonna go in this week and should be finished by the mid of the following week.so the car can be taken upto ttp and tuned on the dyno.if all goes well the car will make its first test and tune on the 29th of this month @ island dragway.with subsequent attempts at the world v6 f-body et record which now stands at 11.91.which i would like to break at the f-body nationals this year in august
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
