ECM junk...
Old Mar 10, 2006 | 06:26 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
ECM junk...
Well Im pretty sure my MAF doesnt work at all seeing as how I smacked it and the engine didnt stutter or anything... It prolly has to do with the wires that got cut when some loser decided to steal it.. Anyways my question here is what would be better?? Switching to the MAP and 749' ECm or replacing my harness and getting a new MAF?? The engine is going to be turboed so Im leaning toward the 749' swap.. Im pretty sure itll cost a little bit more but in the end I think the results will be worth the cost... but if I switched what would I do with my MAF and all the wires that lead to it..?? Thanks
Old Mar 10, 2006 | 07:02 PM
daves12secV6's Avatar
i was debating the swap also, but i looked at it this way, once the maf is maxed,i can tune with wide band 02 and a fmu,or i can tune with custom chips since i just bought a laptop and all the stuff i need to burn my own chips now ,and theres no hassel of swaping harness and parts
Old Mar 10, 2006 | 07:19 PM
Yea but either way I gotta mess around with the harness.. And Im pretty sure Id like the 15psi max stock on the 749' instead of dealing with the MAF and burning custom chips...
Old Mar 10, 2006 | 07:21 PM
What exactly is a FMU??
Old Mar 10, 2006 | 07:42 PM
its a fuel preasure regulator,it goes in the return line to the tank,it increases fuel preasure in relation to boost in preset ratio's 16-1 14-1 12-1 10-1 and so on, very simple way to tune
im only gonna go for 7-9 psi to start, though after a while i may step it up, im gonna keep the maf setup and tune with fmu, till my fuel pump cant keep up anymore, then ill buy a 255 lph v8 pump,if i have to, once i get it tuned pretty good ill fine tune with custom chips
Old Mar 23, 2006 | 05:51 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
pulling codes
wrong post
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
